GM messed my Z up
GM messed my Z up
Well I'm only stuck overseas for a few more days, so I told the wife to take the Z in for the Steering Column recall
She gets it back and now the windows will not go down, the door locks only lock/unlock individually per side, the keyless entry only makes the alarm go off
Yes they tried resetting the FOB and options= still no worky and now they are starting to hint about it being out of warranty
Like that is going to fly after they jacked it up
I've been away from home for 6 months and I was looking forward to my wife picking me up in the Z at the airport
God help them if my Z isn't at the airport waiting for me next week.........exactually the way I left it.
Can anyone shed some light on this situation, from everything I read it should have been in and out no problem WTF
Moderator
They broke it, they fix it. Stick to that story even if the
service wiener starts to cry. Usually you're supposed to
leave with fewer problems than you came in with (and in
your case there was no problem, just a recall notice).
Its possible when they flashed the PCM they disconnected the starbus (common practice) via the 2 connectors by the BCM and then forgot to install one back in or not in all the way after completing the PCM flashing.
Thx
