373 gears seems to have sluggish acceleration when driving
Old 09-15-2004, 05:07 PM
whataretheodds's Avatar
Default 373 gears seems to have sluggish acceleration when driving
i got my 373 gears and i put a few hundred miles on it and yes it does pull hard in 2nd gear, ive notice like sluggish acceleration like when the car downshifts theres not that much go, when like when iam crusing at 40 mph and i step on the gas half throttle and it goes a little and when i floor the gas pedal to the floor the car doesn't scream out loud as it with before with my 273 gears the car moves but not as fast as it did before, i have the gas pedal all the way to the floor and boy it seems like its crawling slowly, my car doesn't missfire or anything like that its just seems to be sluggish when the car downshifts when i get on the gas pedal it doesn't roar as big as it did with my other gears..is this normal? also what mph is a good to catch 2nd gear downshift? also my car is a A4.
Old 09-15-2004, 05:25 PM
2xLS1's Avatar
Have your upshift and downshift tables been scaled for the gear change?
Old 09-15-2004, 09:09 PM
nikon1999's Avatar
yea i have the same problem, if i did it all over again i wouldn't get 3.73's, i do to much highway driving. The only way to take off fast from a roll is shift the car yourself, or hammer it down low (40 or less) Top end just isnt there
Old 09-15-2004, 11:43 PM
only thing i have done is using the hypertech to change the rear end so my speedo will read correctly, but otherwise no my upshift and downshift has not been changed, many people say to keep the shift points the same? but with the hypertech i cant control the downshift? what other programmer can i use that adjust the downshift?
Old 09-15-2004, 11:51 PM
also if i get a stall would this solve my problem?
Old 09-16-2004, 06:55 AM
99 Formula's Avatar
I got 3:73s and didn't really have that type of problem. I did have the computer custom tuned by MTI and a 2800 stall at the same time. Later I went up to a 3600. A higher stall will help keep the motor in the power or torque curve.
Old 09-16-2004, 10:43 PM
how much was the custom tune by MTi?
Old 09-17-2004, 01:06 AM
MyLS1Hauls's Avatar
More gear doesnt hurt topend power...thats total bs. What you dont have now though is a 2nd gear downshift at freeway speeds because the motor would be running too fast, so it has to choose 3rd. Your downshift sweetspots are still there, but they are now at different speeds. I'd personally get LS1Edit or HP Tuners to tweak the max downshift speeds. The stock/hypertech settings arent aggressive enough for my tastes.
Old 09-17-2004, 02:10 AM
2MuchRiceMakesMeSick's Avatar
Yeah, you just need to change your shift points. Does anyone have their 'tuned' shift points that they can post for these guys with 3.73s.
Old 09-17-2004, 01:28 PM
MyLS1Hauls's Avatar
Well the shift points are setup specific. WOT shift points are obviously related to the engines peak power rpm. The part throttle shift points are different, depending on what converter you have. A really loose converter should have higher mph/rpm part throttle shift point to cut down on the looseness feeling. A good setup is to change the shift points by the percentage of the axle ratio change..i.e 3.23-3.73 is 15%.
Old 09-18-2004, 11:31 PM
iam planing on bringing my car to finish line performance so the can hook up the LS1 edit to my car and so they can control the downshifts on my car so i can get back my 2nd gear downshift when iam crusing at different speeds, hopefully this will work
Old 09-19-2004, 12:23 AM
Does anyone have a tuning spread sheet they can share that will have shift points vs rpm
Old 09-19-2004, 01:12 AM
Mooobunnny's Avatar
I went from 2.73's to 3.73's as well....I have no problems like that with them, but if I had it to do over again I would go 3.23 or 3.42, maybe I could actually see if they made any difference at the track if my tranmission actually worked right......
Old 09-30-2004, 04:55 PM
same here if i had to this this all over again i would get 323 or 342 gears, it sucks that these dam 373 gears wont downshift into 2nd gear for that screaming performance when iam crusing at 50 mph or faster
Old 10-02-2004, 09:22 PM
also iam using the stock converter
Old 10-02-2004, 10:35 PM
MidnightWS6's Avatar
Can you adjust the WOT downshifts independantly from the upshifts with LS1 Edit?
Old 10-06-2004, 07:44 PM
iam not sure about that, i wish i had ls1 edit
