Well it dose not look pretty!! PICS
Old 09-15-2004, 07:59 PM
TT-TECH Veteran
Inspector12's Avatar
Default Well it dose not look pretty!! PICS
Wel I knew I had at least one piston broke, I really thought two or three possiblly. Well turns out I had four . And they were all on the same side 1,3,5,7. I took a few pics to look at if you want to know how bad they can be hurt and still run 11.7 @ 125MPH. This is on a FI car. Full weight and street tires. Tony (Nine ball was there. Well he was actually behind me LOL! So I ordered my pistons and rods yesterday I will be building it myself as I do all my own work. I will let you know how it comes out etc...
Old 09-15-2004, 08:13 PM
D Rock's Avatar
That doesn't look good at all, but better than a hole right through the center or something, with that at least you could still run.
Good luck on your next engine.
Old 09-15-2004, 08:20 PM
jrp
SN95 Director
jrp's Avatar
what caused it? too much boost, bad tuning, ect?
Old 09-15-2004, 08:29 PM
CaptUSA's Avatar
Yeah, I'd like to know also?? All on one side.... is that normal?
Old 09-15-2004, 09:59 PM
Senior Member
Country Boy's Avatar
I had the same problem when I used to spray, I blew ALL the ringlands off of #7
Old 09-15-2004, 11:24 PM
pdd
pdd's Avatar
good luck with the fix
Old 09-16-2004, 12:37 AM
1dirtyZ's Avatar
are those stockers?
Old 09-16-2004, 12:47 AM
y2khawk's Avatar
I bet it leaned out
Old 09-16-2004, 12:52 AM
buschman's Avatar
ouch! Clue us in to what you think happened. Very curious to hear why?
Mike
Old 09-16-2004, 10:34 AM
FASTONE's Avatar
Too lean !!!!!!!Too much advance!!!!!!?
Old 09-16-2004, 11:06 AM
NA$TY-TA's Avatar
Damn.... bad luck...... i did the same thig to my stockers....... i think i did it to 6 of them.... holes thru the top of 3 of them.... was the car chugging and white smoke coming out the oil fill??
Kyle
Old 09-16-2004, 11:17 AM
TT-TECH Veteran
Well The tune was as good as it could get with the fact that I was still droppping 20psi of fuel presure. But The first Vortech S/C I had locked up after 10-18miles including dyno time. When the bearing blew it sent a lot of oil into the intake. Oil will lower your octane rating and that is when some of the damage happened. Recived my new unit installed it and it ran good I told several people that it was down on power for some reason, but drove it for a while and to the track. Took it back to MTI fo a retune with a change in my fuel system and that is when I found out I was down 200hp. Started looking and found the old CHoo CHoo train out of the breather. No nitrous. Never knocked or made noise very quiet engine. well going to drop off some parts at the machine shop I'll let you know how it turns out.
Old 09-16-2004, 03:25 PM
Kaneman's Avatar
My #5 piston did the exact same thing. What was odd is it did not hit my cylinder wall at all. My oil ring ended up folding into the missing area.
Kane
Old 09-16-2004, 06:32 PM
v8-7's Avatar
Will crazy ish like that continue to occur even with forged pistons? I mean, yes a bad tune, low octaine, detonation will kill a forged bottom end regaurdless, but what is the likely hood of it with forged pistons? Never see to many thread about people nuking aftermarket pistons, probably takes a lot of punishment.
Old 09-16-2004, 08:15 PM
TT-TECH Veteran
Hope not. Still trying to fix the fuel issue I think I got it now.
Old 09-17-2004, 01:19 AM
ECOJET's Avatar
better than the piston shattering... i didnt know the ring walls could break like that..
forgies
Old 09-17-2004, 01:51 AM
GREATWHITE's Avatar
Let us know what the issue with the fuel system is
Old 09-17-2004, 09:54 AM
TT-TECH Veteran
I am droping fuel presure in the upper RPM range. Was dropping 20psi the last time it was about 10psi so I am getting there.
Old 09-17-2004, 10:16 AM
z-ya's Avatar
Stock pistons are hyperutectic and don't tolerate detonation well as your ring lands can attest to.They are just to brittle compared to a forged unit.
Old 09-17-2004, 03:41 PM
98 Z's Avatar
Thumbs up
Quite a mess you made there! Enough damage to require machining to the cylinders of the motor?
