Variation of the stealth 1 cam?
I picked up a used Lunati Cam that I think is very close to the stealth1 cam or a variation of the B1/T1 cam
the specs are:
adv duration: 283/283
duration @50 221/221
lift 258/258
LSA 116
The markings on the cam are RRS1-221/221-B 116
Anyone know if the ramp rates are the same as the stealth 1 or B1 or if there is a way to tell how much advance is ground in?
Is there web site to get the rest of the specs on the cam using the serial#?
I already e-mailed Lunati but it cam back as a invalid address
Thanks
the specs are:
lift 258/258
LSA 116
Thanks
Originally Posted by narcszm
Advertised duration is seat-to-seat timing. ...duration at 0.001" if you will.
You have the answer to your question in the first post. The advertised duration is 283/283. Comp measures their advertised duration at .006; I assume Lunati uses the same, but do not know for sure.
Those are slooow ramps if the 283 is at .006. A 222 @.05 XE ramp is 275* and the XE-R lobe would be 271*
To calculate ramp rate:
(DUR@.006)-(DUR@.050)=ramp rate
49< is an XE-R ramp rate or similar
53> is an XE ramp rate or similar
That 222 you mention has a rate of 62 which isn't even an XE, so yeap very slow rates.
I was trying to get the ramp rates for the stealth cam i know mine
