What kind of gains between 6.0 H&C vs. 5.7 H&C????
Old 09-19-2004, 10:23 PM
Speedfreaks101's Avatar
Default What kind of gains between 6.0 H&C vs. 5.7 H&C????
I know this a very broad question but how much power can be gained going from a 5.7 to a 6.0 using a cam with the same specs and identical heads? I know that there is not a presise answer but can someone get me in the ball park.
Is there a general percentage like 3-5%?
An example would be if you had a 5.7 that put 425 to the rear wheels what would you expect a 6.0 to put to the rear wheels with the only differnece being the bore?
Thanks for any help,
Bart
Old 09-19-2004, 11:59 PM
jrp
SN95 Director
jrp's Avatar
i assume were talking ported and the same combustion chamber size?
Old 09-20-2004, 12:17 AM
cyphur's Avatar
i do believe he's referring to a h/c'd car with identical specs. so yea....just give him a guesstimate based on difference of bore alone.
Old 09-20-2004, 04:40 AM
Yes sir. Every thing else being a constant the only variable being the bore size.
Later,
Bart
Old 09-20-2004, 11:05 AM
dug
dug's Avatar
6.0/5.7=1.05
Youd probably see a 5% increase in power and torque.
Old 09-20-2004, 11:49 AM
WS6snake-eater's Avatar
Originally Posted by dug
6.0/5.7=1.05
This is in addtition to an 80lbs gain on the nose of the car. General consensus is that the additional weight of the iron block negates the minimal horsepower gains that you will see.
Old 09-20-2004, 07:59 PM
Thanks y'all.
Well I am trying to decide if it is worth going to a 6.0 aluminum block over a 5.7. I can pick up a 5.7 pretty cheap and just need to figure if I can make more hp per dollar in other places than the 6.0 block. Its going in a 85 RX7.
Later,
Bart
Th
Old 09-20-2004, 08:35 PM
The 6.0 block is not aluminum it is iron. The 5.7 is aluminum. Thus the weight difference. Now if you can get someone to bore out an aluminum 5.7 to 6.0 then it might be worth it, however, if they are allready there you are better off going bigger. Just stick with the 5.7 it's the way to go unless you plan on going all out.
Old 09-20-2004, 09:45 PM
Ragtop 99's Avatar
Maybe he means an LS2 Block.
I would go 5.7 and put the money into good components or stroker crank if you have the cash.
Old 09-21-2004, 07:49 PM
I was actually speaking of the LS2 block and picking one up from scoggin dickey. In order to take the block to a 4.0 bore it would have to be sleeved and I am looking for a cheaper alternative.
later,
Bart
Quick Reply: What kind of gains between 6.0 H&C vs. 5.7 H&C????
