I took apart my stock heads to see this...
Old 09-20-2004, 08:36 PM
YOOFORMULA's Avatar
Default I took apart my stock heads to see this...
Any ideas what could cause this? Hotcam with 918's and hardened pushrods. I dont know when it happened, but I drove probably 30k miles on that cam. There were only 2 valves that looked like the one on the left.
Attached Thumbnails I took apart my stock heads to see this...-00_00015.jpg   I took apart my stock heads to see this...-00_00016.jpg
Old 09-20-2004, 09:21 PM
M6HuggerSS's Avatar
maybe valve float? did the piston hit the valve?
Old 09-21-2004, 01:19 AM
YOOFORMULA's Avatar
There wasnt even so much as a nick in the piston or the valve when I cleaned them all up so I have no clue.
Old 09-21-2004, 03:58 AM
CaptUSA's Avatar
That's really weird. Glad you're okay though. Could have been much worse.
Old 09-21-2004, 11:18 AM
Juiced's Avatar
that could have been real bad
Juiced's Avatar
glad to see that your still running
Old 09-22-2004, 12:26 PM
kenkaru's Avatar
i wonder if that could that happed if the seal was not installed all of way, allowing the spring seat to bounce around?
Old 09-22-2004, 01:56 PM
marc_w's Avatar
Besides the seals(?), I'm not quite sure what I'm looking at...
EDIT: I get it now. Possible valve float hammering down on the seal...
Old 09-22-2004, 04:02 PM
Another_User's Avatar
When you changed your springs, did you use the new spring seats?
Old 09-22-2004, 04:03 PM
marc_w's Avatar
Didn't crank down too hard with the spring tool, right?
Old 09-22-2004, 05:13 PM
DaddySS's Avatar
I assume you're talking about the mushroomed seal? Probably compressed the spring too much during the install.
Old 09-22-2004, 10:21 PM
Classic's Avatar
Did you put 30K miles on a single set of 918s or have you changed them out?
Old 09-23-2004, 01:58 AM
CaptUSA's Avatar
Even if he had 30k on those 918's, they should have been just fine on a hotcam. TR's had 918's go over 60k with no issues.
Old 09-23-2004, 08:35 PM
YOOFORMULA's Avatar
Sorry about the confusion, but the springs only had about 10-15k max. The cam and the rest of the valvetrain had about 30k on em. The guides were fine when the springs were installed and I never went past stock rev limiter so I have no clue. Oh well, got some duals in there now with LS6 valves so now if I could just get the damm clutch fixed again, I might be able to drive it...
Old 09-24-2004, 06:16 AM
PREDATOR-Z's Avatar
You know LS6 valves are a bit longuer right?
Old 09-24-2004, 06:35 AM
SAPPER's Avatar
^^^^^^^ This is one of my votes, but also having 15+ yrs working cyl heads, I have seen where the valve guides aren't the same height. as little as .050 can cause this. I always cut the top of my guides down .100" just to be safe and the PC seal still has clearance at the bottom and I make sure they are all the same height from the spring seat.
Old 09-24-2004, 09:18 AM
YOOFORMULA's Avatar
Yeah, I figured that one out about 10 miles after the install and compensated with shorter pushrods.
