bbk 80mm th-body worth it over stock ported?
!LS1 11 Second Club
I think the problem with the 80mm BBK is that despite its larger diameter, the diameter of the intake is smaller than 80mm, therefore you won't have a clean passage for the air to flow through.
port your stocker. if you have the patience, you can do a really nice job yourself. take a dremel with a nice conical shaped rounded cutting bit, a few sanding wheels for the dremel, a few sheets of different grit sand paper, and you'll be good to go. putty-form jbweld works really well
Originally Posted by NoseUpChromeDown
It's not what the unit will flow @ 100% throttle, it's what it'll supply at part throttle compared to the factory unit.
That statement was pertaining to what was said about factory cars benefiting from something as large as a 90mm setup.
You do not mash your pedal all the way to the floor off the line. If you do, you obviously don't know what you're doing. As the engine speeds up, your foot should get heavier. Obviously quick-like, but that's how you work the throttle. No matter what you're on, track, or street. @ ALL throttle positions, a larger unit would be an advantage, period.
Even on a factory intake. Anything over 80mm may be useless there, but it's definitely better than 75mm.
Thats the first i've heard of this technique. I assume you are alot faster than 12's. But for us slower cars... full thorttle all the time works best at the track.
