Cant get Trans out of car.....Wana get new converter in ASAP
Old 09-24-2004, 09:12 PM
SSPerformance's Avatar
Default Cant get Trans out of car.....Wana get new converter in ASAP
I got all 6 uper bellhousing bolts out. the bottoms ones. The 3 alan bolts out the converter. The only thing left is the 2 cooler lines and the one dip stick bolt in the block. But i yank the trans left to right and the motor moves with it. i cant even get the trans to seperate from the block not even a 1/8 of an inch.... Is there somethign im doing wrong???????
Old 09-25-2004, 08:04 AM
Ragtop 99's Avatar
Did you remove the driveshaft and try sliding the tranny backwards?
Old 09-25-2004, 08:53 AM
LOL yes i removed the drive shaft and trans crossmember.
Old 09-25-2004, 09:12 AM
NO CATZZ's Avatar
The block and bellhousing are aluminum and the dowel pins are steel. This combination creates corrosion in the pin area which makes it hard to seperate. Carefully wedge a large screwdriver or pry bar on each side to 'break' the bellhousing loose from the block. When you reassemble use some anti-sieze on the dowel pins.
Also, double check everything. I have made plenty of bonehead mistakes by simply overlooking something.
Josh
Old 09-25-2004, 09:35 PM
Farmer2's Avatar
Alot of people miss the top bolt dead center on the top. And like mentioned the dowel pins could be corroded to the alum.
Good luck and let us know how you make out!
Old 09-25-2004, 09:56 PM
Jorday's Avatar
The first time I had to remove my trans it was stuck. After enough prying on it, it finally came loose from the dowels.
Old 09-25-2004, 10:06 PM
itchygomey98's Avatar
I had to pry mine apart too.
Old 09-25-2004, 10:16 PM
yea i had to get a big *** tire iron to pry it apart
Old 09-27-2004, 11:30 AM
bowtie9696's Avatar
When you are prying it apart, leave a couple bolts in. Just run them down a couple of threads so that the tranny doesn't fall on you when it finally breaks free.
