A Peak Inside The Engine Of The APE Shop Car
Old 09-30-2004, 02:56 AM
Uthinkso's Avatar
Default A Peak Inside The Engine Of The APE Shop Car
Here is a sneak preview inside the powerplant of the APE Shop Car, now dubbed Project Black Mamba.
Our goal is to have it fired up and testing within the next two weeks, our second goal is to run 7's at the Thunder Shootout in November, and after who knows.
It will be a 359ci Iron Block with our big daddy Procharger F-2 strapped to it. With any luck we should be able to make north of 1200hp at the flywheel with this set-up. Stay tuned for details.
Pics can be seen here.
Old 09-30-2004, 03:01 AM
granitemonkey's Avatar
Looking good Nick That intake is awesome
Brandon
Old 09-30-2004, 05:26 AM
KimberWS6's Avatar
Old 09-30-2004, 05:59 AM
BTL FED's Avatar
Looks sweet, How many passes do you plan to get out of the rods?
Old 09-30-2004, 07:25 AM
427's Avatar
Nick,
Ran a 320ci gen 1 last night with f2. Made 1300+ at 31 psi.
That thing will rock if the head gaskets are happy!
Kurt
Old 09-30-2004, 08:18 AM
Under criminal investigation for fraud
Chris@AP-Engineering's Avatar
BTL FED - generally we can get up to 120 runs out of those rods.
Kurt, happy gaskets are what we are after
Old 09-30-2004, 05:18 PM
under_construction's Avatar
How light is that Callies crank?
Old 09-30-2004, 05:21 PM
CHRISPY's Avatar
awesome looking crank!! Those rods will take a nice bit of shock too
they tend to "stretch" a good bit compared to steel dont they?
Old 09-30-2004, 07:33 PM
Uthinkso's Avatar
Originally Posted by 427
Nick,
Kurt
Happy gasket are what we are after indeed!!
We shall see here pretty soon assembly should be done this weekend.
Old 09-30-2004, 10:05 PM
The Callies crank weighs in at 38lbs!!! Special thanks to Brook, Nick and all of the guy's over at Callies for hooking us up with this killer Crank! BTW, this is there LS1 racemaster XLS. If anyone wants one you can buy them through us.
Chris, the rods don't stretch as much as they used too. GRP has come a long way in aluminum rod technology. We now get a lot of runs out of these rods. Also a special thanks goes out to Troy over at GRP for getting us these killer rods.
Old 09-30-2004, 10:16 PM
Flyer's Avatar
Is that the crank that comes in your forged shortblocks, mainly the 408?
Old 09-30-2004, 10:31 PM
P Mack's Avatar
AFR heads?
Old 09-30-2004, 10:50 PM
No sir! We use just a standard racemaster in our 408's. You could upgrade to that crank though.
No AFR heads, just some badass 4.8/5.3 liters from ET Performance. Big thanks to Cary, Craig, Mike and the rest of the guy's at ET that busted their *** to get me these heads. They are simply the best 5.3 liter heads that could have been made!!
Old 09-30-2004, 10:52 PM
Doore39's Avatar
Old 10-01-2004, 08:37 AM
Super Moderator
Reckless's Avatar
Looks nice Nick. Did Callies make you a crank, or turn down a 3.622 crank to drop the 5cid? Love the rods
Old 10-01-2004, 08:39 AM
Todd, they made that crank for us.
Old 10-01-2004, 11:28 AM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
What would a crank like that cost?
Old 10-02-2004, 05:05 PM
I think that the price is right around $2200.00 for a crank like that. You want one J-Rod???
Old 10-02-2004, 05:21 PM
strokedls1's Avatar
Looks good. You are gonna need some serious clearancing for that f2. Should be an awsome ride.
Old 10-02-2004, 11:20 PM
What clearancing??? The F2 fit perfectly on the center of the engine. Right where the water pump used to be!!
