232/230 580 110 LSA Cam Questions??
Old 10-01-2004, 07:22 PM
Bill Bowling's Avatar
Default 232/230 580 110 LSA Cam Questions??
The cam is a custom grind from Patriot Performance --232/230 580 110 LSA?? Has anyone tried this grind before?
Thanks,
Bill
Old 10-01-2004, 07:26 PM
Ed Curtis's Avatar
Cool
That's Chris Straub's design..
Ask him or Gomer about it....
Ed
Old 10-01-2004, 07:46 PM
gomer's Avatar
Give me you Email addy and I'll shoot you a mail with my dynographs from it. Be prepared for a rough idle and I hope you have a good tuner to get it driveable.
Old 10-02-2004, 01:53 AM
GrannySShifting's Avatar
Thats easy to get to run in a 6 speed
Old 10-02-2004, 10:05 AM
DAPSUPRSLO's Avatar
That is exactly what I was thinking.
Old 10-02-2004, 09:05 PM
gomer's Avatar
it may "run" but I promise you that it won't make power for ****. I swapped it out for an "old school" B1 cam and made more torque and power. The Reed Cam lobes that it is ground on is hurting it IMHO. The same specs on a comp X-ER would make some good torque.
Old 10-02-2004, 09:55 PM
Reed Cam lobes?
Guessin its a really lazy lobe?
i be interested in seeing thsi vs your B1 cam. even the B1 cam is a lazy lobe
Old 10-02-2004, 10:01 PM
jrp
SN95 Director
jrp's Avatar
what was the ICL and duration @ .006?
Old 10-02-2004, 10:11 PM
gomer's Avatar
Originally Posted by GrannySShifting
Reed Cam lobes?
When I got the cam from Patriot to test it was in a REED CAM box, yellow and blue. The dyno graphs are on my computer at work, I'll post them up Monday when I get back to work along with all the other data I have from that test. I went from a 231/237 to the 232/230 then to the B1 cam all on the same set of heads. I have all the dyno data that I can post monday.
Old 10-03-2004, 05:42 AM
gomer's Avatar
Here's the specs that I have written down off that cam
Duration @.006 284/282
Duration @.050 232/230
Duration @.200 144/143
Lift was .578/.578. LSA was 110 and I ran the cam at 108icl and 106icl. 108 gave the best numbers.
Old 10-03-2004, 09:08 AM
The top of that cam is lazy. It would have liked being installed straight up best I would say
Old 10-04-2004, 08:21 AM
Cstraub's Avatar
Bill,
Who is offering this camshaft?
Chris
Old 10-04-2004, 10:24 AM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
XE lobe 3756
Duration @.006 286
Duration @.050 232
Duration @.200 144
Lift @ 1.7 is .541
XE-R lobe 3719
Duration @.006 285
Duration @.050 232
Duration @.200 148
Lift @ 1.7 is .575
XE-R lobe 3718
Duration @.006 283
Duration @.050 230
Duration @.200 147
Lift @ 1.7 is .573
Other than lift, all the specs on the comp lobes vs your lobes on the intake side could be within grind specs for the mfg.
So, are you saying on your combo the B1 (221/221 114) made more power than the 231/237 and Chris' grind? By power do you mean dyno numbers, or track time?
Was your combo optimized for those cams?
Old 10-04-2004, 01:11 PM
gomer's Avatar
Originally Posted by J-Rod
XE lobe 3756
Duration @.006 286
Duration @.050 232
Duration @.200 144
Lift @ 1.7 is .541
XE-R lobe 3719
Duration @.006 285
Duration @.050 232
Duration @.200 148
Lift @ 1.7 is .575
XE-R lobe 3718
Duration @.006 283
Duration @.050 230
Duration @.200 147
Lift @ 1.7 is .573
The 231/237 made the most power out of the three. The only thing I changed between the 3 cams was A/F tuning.. all other components were the same. None of the 3 cams were ever ran at the track due to my car having a 10 bolt rear at that time. I'm not at work today and my runview along with all the dynojet run files are on my office PC. I'll post up a comparison graph tomorrow.
Btw... I never said that Chris had anything to do with the grind I was just given the cam to test by Patriot and after I got the data I took it out and gave it back to Patriot.
Old 10-05-2004, 01:02 PM
gomer's Avatar
Here's a graph of the patriot cam, F13, and B1 all together. All of these runs were dyno'd the same way.. except I had 3.42's with the patriot cam and 4.10's with the f13 and B1. Open cutout and all belts on the car. I can't find the 231/237 run files right now... but I'll keep looking.
Attached Thumbnails 232/230 580  110 LSA Cam Questions??-patriot_camcompare.jpg
Old 10-05-2004, 03:25 PM
Who makes the F13 cam? I like the numbers. I would also like to see the 231/237 numbers.
It is hard trying to select a CAM. I want low end torque but like the HP also.
Thanks,
Bill
Old 10-05-2004, 03:34 PM
Do you have the numbers for the cam you have: Precision Race Components 225 Cam??
Bill
Old 10-05-2004, 03:47 PM
gomer's Avatar
Bill
Here's a graph of before and after the 12 bolt swap. This is using the PRC heads and the PRC 225 cam.
Attached Thumbnails 232/230 580  110 LSA Cam Questions??-rearswap.jpg
Old 10-05-2004, 03:58 PM
Talking
I like the smooth curve that cam puts out. How does it idle? Is this car a daily driver or just for the track? How do you think this cam would work in a daily driver car?
Thanks Gomer.
Bill
Old 10-05-2004, 04:08 PM
gomer's Avatar
Thanks Gomer.
Bill
Car has a noticeable idle, not anything like a "big" cam. I drive the car 70miles round trip to work and back every day. It gets ALOT better gas mileage than my 2001 4x4 Tahoe, so I end up driving it the most. Heck, my wife even drives the car a good bit.
