Ls1 Motor Plates Now Available Through Ape!
Under criminal investigation for fraud
LS1 Motor Plates Now Available Through APE!
We are now offering prefit aluminum LS1 motor plates for 4th gen F-body's. These plates come with everything you need to install it in your 4th GEN!! The kit comes with the following components:
.250" thick custom precision laser cut aluminum motor plate
(2) Prefit precision laser cut steel mounting brackets
(6) Grade 8 3/8" bolts, washers & nylock nuts
These motor plates are the best on the market and require NO cutting, grinding or fitting on the customers end! Simply take them out of the box, weld on the mounting brackets and you are ready to install your engine. Simple as that!!
We have these on the shelf ready to go!!
The complete kit price is $195.00
PIC's will be posted later tonight
Never a stupid question! It depends on what you call a daily driver. If it is a car that you use for your only source of transportation......then no. If it is a weekend cruiser, then ya you can probably get away with it. These are generally designed for the race car type. It will allow you to run bigger header, by freeing up some clearance down there. Also it will keep the engine from moving, thus allowing more torque to the rear wheels.
Thanks
Thanks
I have the motor plates in stock, ready to go! I wil have to make up a mid plate. We are currently out. It would take me about 3 days to get a mid plate ready.
8 Second 6 Speed Director
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
1 Post
chris,
why would this not be good on a daily type of driver? i am just curious as i am considering doing this, and i put about 5000 miles on the car per year.
thanks!
taner
thanks!
taner
Taner, you would most likely be able to get away with this mod. The reason that it won't be good for say someone that puts 10,000 miles or so on their car is because with the rigidity that it wil give the car, bolts tend to come loose. When using these plates you do not get the amount of vibration transfer as you get with the stock motor mounts. This leaves a lot of the vibration being absorbed by the engine and parts that are connected to the engine. I am not saying someone couldn't make a plate work for a daily driver but I don't want to give the illusion that it will for sure. I do not know anyone that has tried a motorplate on a daily driver. Hope explaining my thoughts on this help you, Taner.
Thanks
Thanks
We are expecting the mid-plates to arrive at the shop later today, so I will get pics up a.s.a.p.
The mid-plates are reccomended with use of one of our motor plates and will sell for $85.
