Best streetable rear-end?
Well, I will be getting a 99 - 00 Camaro SS in a few months, and i've decided to do suspension and rear-end before starting on the fun stuff. It seems like Moser makes the best rear-end. This car will be my daily driver, and I will take it to the track a few times a month. I want the strongest rear-end that I can have and it still be a daily driver. What should I get? Thanks, Ryan
Originally Posted by Armageddon
12 bolt is your best bet. less drivetrain loss. Holds plenty of power and you can get every option imaginable for one.
Originally Posted by matts22
I wouldn't say "every option imaginable" as you can't even get a locker for a 12 bolt to my knowledge.
If you want a locker you can have one... they are out there. Most are 30-spline variations though, but the TruTrac helical gear design is available in 33. Depends what you'll be using the rearend for I guess.
I need this rear-end to hold up to at least 550 rwhp, because I plan on going with a 408 stroker a year or two after I get my car, and than mabey supercharging it down the road. Would a Moser 12-bolt be the best way to go, or would a 9" be better?
Rear End
I wouldn't say "every option imaginable" as you can't even get a locker for a 12 bolt to my knowledge. Ford 9 inch rears offer a lot more options, they just eat up more power.
there shouldn't be any problem going with a 12 bolt...my vote goes to strange though....i hear a few things bad about moser....9"=no abs as well...just to let ya know in case you didn't already....12 bolt's should hold most anything you throw at it...the thing that usually breaks is the posi...so either get the best posi you can or get a spool...you shouldn't have problems
Originally Posted by CarrotcarZ
sO YOU LOSE POWER W/ THE 9"??
umm i don't know the differences but there are tons of moser vs. strange threads that have loads of info on both of them...good luck with your decision
i think basically strange is a better fit and much quiter...moser has better axles...but then again how often do you hear of axles breaking...rarely if ever...i think what you are wanting is a strange 12 bolt with a high performance POSI...not a spool...your car will hope around on turns with a spool...you will get annoyed with that i'm sure...this is where a daily driver is subjective...some people won't mind things like that or having to constantly be tapping the gas to keep from stalling...and some people won't even be able to take a slightly stiffer clutch from like a spec stage 3...so daily driver is all up to you...we just provide the effects of your mods...you decide whether or not that is suitable for YOU
Originally Posted by AllThrottleNoBottle
Well if you can't have ABS with a 9", then i'm going to have to get either the Moser 12-bolt or Strange 12-bolt...what are the main differances between the two?
As far as a 12 bolt, everything I have heard steers me away from the Moser. The Strange is more expensive, but seems to have less issues as far as gear whine and even breakage.
But take my opinion with a grain of salt, because I don't have experience with either. I will upgrade my rear in the future and still have not decided. So I am in the same boat as you.
Kleeborp the Moderator™
After all the reading I've done, I'm leaning heavily towards the 9" since I have TCS (and can thus keep my ABS). I don't go to the track all that often, but when I do, I want to be able to dump on full slicks and not have any problems. I'm only a bolt-on car (for now), and I haven't heard of anyone breaking a 12 bolt on slicks with just bolt-ons, but I HAVE heard of the 12-bolts whining after doing so, and that is NOT acceptable.
The 9" also has the added benefit of a removeable center section (the part that has the posi/spool/locker and the ring and pinion), so you could set up one with a nice posi (like and Eaton or Torsen T2R) for the street along with some nice cruising gears to save on gas mileage, and then you could buy a different center section for track use only with taller gears and a spool. The design really lends itself to being the most versatile.
The big issues with the 9" are added weight, slightly less efficient than the 12-bolt, and the possibility of the torque arm banging the tunnel since it sits about 1.5" farther to the drivers side than other rears (at least from what I read). I'll most likely find this out first hand after the first of the year when I have the cash together to do this. A buddy of mine had a Currie 9 shipped to his door with a Locker and all the stuff for ABS/TCS for ~$2200. I'll definitely be getting a posi with mine.
Don't blow your money. Build the ten bolt. Put some good axles and a nice posi in it and you will have enough rear to do fo a quick street/strip car. The M/W Masterline axles are nice and what posi you get is up to you. If you shop around you could do a posi, axle, gear swap for less then a grand. A 10 bolt is lighter and more efficient. There have beenmany a racer running low 9's on a 10 bolt. I run a 12 bolt and have 500 rwhp, and planned on putting 1000 to the ground. But, hopefully not though if I ditch my engine. If you plan on making more then 550 rwhp though, I would just bite the bullet then, and get the 12-bolt. Good luck with you decision.
If you have a 4-channel, I would go with a 9" because you have a M6 and are planning over 550rwhp. 12 bolts will tend to break with manual trannies due to the shock when you dump the clutch, while it will survive in an auto because you can preload it.
BTW, I have a 3-channel ABS, so I went with a Moser 12 bolts (Eaton posi, 33 spline axles, 3.73's). I have a 382 stroker in my M6 Firehawk (411rwtq). 3K miles and no problem so far. It has taken everything I have thrown at it and it's still "dead silent". However I have not took it to the track yet.
Oh, and don't forget to swap your driveshaft for a stronger one. With a supercharged 408, you will snap your stock aluminum DS like a toothpick.
Well where is the best place to buy a 9"? If I were to get a 12-bolt it would be a Strange after reading up on the Moser vs. Strange, so its either a 9" if I have 4-channel, or a Strange if I have 3-channel.
Yeah..now heres some good advice ....why dont you do this.
