Can i use a 2 step??
Old 10-20-2004, 01:28 PM
stangeater01's Avatar
Arrow Can i use a 2 step??
I have a 2001 ws6 and i wanted to know if i can use a 2 step on my car? Which one should i get? How does it work/what exactly does it do?? Any advise would be greatly appreciated.
Thanks Richard
Old 10-20-2004, 05:21 PM
Bill Bowling's Avatar
Question
What is a 2 step??
Bill
Old 10-20-2004, 10:07 PM
Delphi's Avatar
Default New 2 step code developed for all LS1 PCM's
Originally Posted by Bill Bowling
What is a 2 step??
Bill
A 2 step is a module that has 2 different RPM pills and is used in conjunction with appropriate coil pack modules and is triggered by a trans-brake solenoid in the auto transmission.
Operation goes like this at a drag strip.
Car is staged with trans-brake on which engages first and reverse gears at the same time. This stops the car from moving while the stall convertor is loaded up to rpm rev limiter of pill #1. On the release of the trans-brake the reverse gear is disengaged and at the same time pill #2 is now the new rev limiter which would normally be set at your usual highest RPM point.
Last week we finalized new code for a 2 step operation within the LS1 PCM.
No 2 step module and coil packs required as the standard PCM does it all by its self.
Old 10-21-2004, 02:29 PM
so this means i can use one?? who makes them and what one should i get??
Thanks Richard
Old 10-21-2004, 02:38 PM
1fastWS6's Avatar
If you don't know what it does, why do you want or think you need one???? Not trying to flame, just curious.
BTW, Harlan is the only one that makes a LS1 compatible 2-step. www.harlan-engineering.com
Old 10-21-2004, 02:41 PM
1fastWS6's Avatar
Delphi.....how do you plan to trigger it and turn it off???? I assume the PCM sees the factory clutch switch to turn it off, but I like to know how you're going to activate it.
Old 10-21-2004, 03:28 PM
BADSZ28's Avatar
That's a good question. Also how are you incorporating this into the PCM? Can it be done with HP tuners? I don't suppose you work for Delphi do you?
So is Delphi getting in the performance aftermarket ring now?
Old 10-21-2004, 03:35 PM
gameover's Avatar
there are a number of threads on our forum about this, but the short answer is "coming soon + more, more, more"
Old 10-21-2004, 04:45 PM
well let us know when it is available
Old 10-21-2004, 05:24 PM
Delphi's Avatar
The Delphi PCM has many unused inputs/outputs that can be used providing the code is changed to activate them. A single wire from one of these unused inputs to the trans-brake solenoid is all thats needed to trigger the 2 step code within the PCM. This is just one more feature that "RTLS1" can give you.
Old 10-21-2004, 06:01 PM
Delphi's Avatar
Delphi is my Nick name on many forums. Dicks Electronics is my business name. I don't work for Delphi. We have been specializing in GM ECM/PCM performance tuning and developing scan tools for 16 years. Many see us as leaders with regards understanding the internal workings of the Delphi PCM. The 2 step code is another first for us.
Old 10-21-2004, 06:58 PM
slow's Avatar
but your 2 step requires a seperate input?
i was hoping it would be like the 99+ fords where you don't need anything but the tune
Ryan
Old 10-26-2004, 12:26 PM
smeshey's Avatar
Default 2 step
Ok here is a question with harlens 2 step isnt it cutting out spark so you are sending raw fuel thru the exhaust in to the cats. Which in no time will damage the cats. For guys like myself without cats this would be ok. Still doesnt seem to be the best way to go. For a car with cats sounds like problems to me. Scott
Old 10-26-2004, 04:32 PM
WS6snake-eater's Avatar
Do they work with 4l60E's? I didn't think that a trans break was available for the 4l60e's.
Delphi's Avatar
It is for this reason that we cut fuel on our RTLS1 2 step PCM.
Old 10-26-2004, 04:42 PM
y2khawk's Avatar
That's why I explicitly say DO NOT USE WITH CATS right in the instructions.
Spark drop is the way most if not all of the currently available options do it.
IMO, if you start messing with fuel and don't shut the injector off completely or at the right time you lean that cylinder out real quick. I'd rather have a weak spark from short dwell than a lean hole.
Not to mention even injector shutoff can damage CAT's, unburt air does neat things to brick temps in the catalyst.
In any case, a 2 step is a race application piece.
carry on
Old 12-17-2004, 04:03 PM
john3daly's Avatar
Yes...it's an old thread, I know. I really want one of these since I've got a stall on the way now. I don't have cats, as you can see in my sig. Can I use this on the stock 4l60e? Can I just use the foot brake instead of a transbrake?
I'm guessing, stall, tranny cooler, 2 step, and DR's....will that be a safe set up for a daily driver? Does the 2 step have to be engaged and then shut off?
Thanks.
