Compression ratio & cubic Inch Calculator
Not sure if this is a repeat but here is a very helpful calculator.
http://www.c5frc.com/calculators/Com...Calculator.htm
SN95 Director
no offense but those kinda calculators are a dime a dozen. also some of the specs are "incorrect" though they fall into GM's tolerances.
stock 99+ (5.7) chamber size is 66.7
deck heigh checks out anywhere from -.003 to .008
gasket thickness is .052 or .054 depending on graphite or MLS
it seems as if those above specs were put together to come up w/ the 10.1 CRr that that factory states even though alot of calculations come out to 10.22
bic, calc, calculater, calculator, calulator, compresion, compression, cu, cubic, gm, googlecom, inch, inches, ls1, ratio
