clanking in the rear
Old 10-27-2004, 12:28 PM
777's Avatar
Default clanking in the rear
every time my automatic car downshifts from 2nd to first it makes this clanking noise...or popping noise...only once though...or if i'm going slow in a parking lot and it shifts to second it will do it as well...what is the deal...rear-end broken?
Old 10-27-2004, 03:26 PM
777's Avatar
T T T
Old 10-27-2004, 03:28 PM
8-Pack's Avatar
Have you checked your universal joints? What about the transmisson mount?
Old 10-27-2004, 03:50 PM
777's Avatar
Neither...i thought it might be the universal joints....i left it alone for awhile since i have been trying to sell it..but now it is just getting annoying and it may cost me money in the long run
Old 10-27-2004, 04:11 PM
8-Pack's Avatar
Both are pretty easy to change, and arent to expensive.
Old 10-27-2004, 07:09 PM
Tiger2o69's Avatar
Its also easy to change the fuid in the rear. You can take a look in there but I dont think it come from there. It probably needs changing anyway.
Old 10-27-2004, 07:16 PM
JEB99TA's Avatar
I'm on my 3rd LS1 Trans Am and they all have done the same thing. I've asked dealerships and numerous individuals ... usually get the same answer. I even had my 3.73 gears installed and they do it, too. As long as it's not a hard hammer sound or crunching sound, I think it's OK. Check your front seal where the driveshaft connect to the rearend to make sure it hasn't leaked fluid out, as the other dude said may have happened. If your fluid is OK, then, it seems to be normal to me.
Old 10-27-2004, 08:22 PM
TraajicLS1's Avatar
mine did that
you have a spohn torque arm?
mine did that all the time , returned my car back to stock .....and now it doesnt do it anymore
Old 10-27-2004, 09:23 PM
777's Avatar
oh no...this is all stock v6...except for exhaust...i've been trying to sell it and buy an trans am for quite some time...it's just been a long process and so far has not been too succesful...selling this car just started since i'm getting closer and closer to getting the trans am...
