Newest Version of LS1edit..??????
1.5 is the newst version.
I have Version 1.21. Is this compatible with newer versions of LS1 Edit?
Example....I am reading my PCM, which was programmed by someone with a newer version of LS1 Edit. That same person is going to use the Edit file to make modifications. (They are recieving it via email because they are 300 miles away) Once they return it, I'll reprogram my car with the new Edit File.
1.21 Read--->1.5 Modify--->1.21 Re-Flash
Will this work?
Will this work?
Originally Posted by Jancarich
1.5 is the latest upgrade. You can't download it, if you are out of upgrades from carputing you have to pay for it What version are you using now??
PM me you email address
