Woohoo!! 11.doh!!
Woohoo!! 11.doh!!
11.DOH!!
Hit the track for the last weekend of the year.
DA was good today but unfortunately we had a direct 15mph headwind and traction sucked.
Weather conditions:
baro: 30.7
Temp: 38 degrees
Dew Point: 17.6
wind: 15mph direct headwind
track elevation: 700ft
DA: -1165 feet
got to the track around 12:00pm and threw on the slicks and tech'd.
Identical setup as last weekend (cats, single cutout, 28x9 inch slicks etc)
First pass I spun, lifted and hit it again
Sixty: 1.64
330: 4.63
1/8th: 7.11
mph: 99.18 new best!
1000: 9.27
1/4: 11.094 new best!
mph: 123.14 (let off early by accident)
Got the slip saw the first 11.DOH and celebrated.
Hotlapped the car:
Spun and had to lift again
Sixty: 1.64
330: 4.63
1/8th: 7.11
mph: 99.89 ALL TIME BEST 1/8th mph!
1000: 9.27
1/4: 11.080 ALL TIME BEST ET!
mph: 125.85 (stayed in it this time till after the traps)
Another new best!!
Hotlapped the car AGAIN
Spun AGAIN!
Sixty: 1.65
330: 4.64
1/8th: 7.12
mph: 99.42
1000: 9.27
1/4: 11.094
mph: 123.14 (let off early again DOH)
I ran IDENTICAL ET/MPH to the first pass down to the 1000th LOL!!
After that pass decided to let the car cool for awhile. Unfortunately the track started getting worse after that and the best I could do was a couple of 11.1's with 1.7 sixties
If it wasn't for that damn headwind and greasy starting line I would have had tens for sure and over 100mph in the 1/8th!!
What a great way to end the year!
Weather conditions:
baro: 30.7
Temp: 38 degrees
Dew Point: 17.6
DA: -1165 feet
Sixty: 1.64
330: 4.63
1/8th: 7.11
1000: 9.27
Hotlapped the car:
Sixty: 1.64
330: 4.63
1/8th: 7.11
1000: 9.27
Another new best!!
Spun AGAIN!
Sixty: 1.65
330: 4.64
1/8th: 7.12
mph: 99.42
1000: 9.27
1/4: 11.094
Thanks guys!!!
Thanks Brian! Good luck tomorrow!
Hopefully the track prep and wind is more cooperative for you that it was for me LOL
Originally Posted by Fireball
Good job chris
That good air is making its way to MIR tomorrow...
Wonder where I'll be
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
good job Chris! sucks you have to wait until next year now to get that elusive 10 second run. I'd almost consider a road trip to the next closest track
Derek
Derek
Thanks guys!
Winter/spring items:
Solid rear swaybar (wolfe or BMR)
Hal shocks and springs
4.33 gears (instead of 4.11s)
Assistance from Roman and Taner on setting everything up
I might do a cam swap as well. (Something that'll peak a little higher (6300rpm and carry power to 6800rpm while remaining emissions legal).
Cam right now is great and makes awesome torque and HP but peaks at 6000 and carries to 6600rpm.
Goal for the spring is 10.70-10.80s through cats and consistent 1.4 sixties.
Yeah I am thinking about 28x10s if I go with 4.33s.
I should have went to the track yesterday. A friend of mine with a Z06 was there on sat (same day I ran 11.0s) and was running 12.4@118mph.
Yesterday (Sunday) the wind died down and the track was stickier. He went 12.20@120mph.
ARRRGH!!! Would have had my ten second slip!
yeah track prep sucked for me as well this weekend along with some other things
I also need some suspension help and a tire change too. Just goes to show you're not alone
You'll get those 10's next year, congrats on your new best! Take it easy
