head help
head help
Hey guys i was wondering if there would be any diff in streetavility, durability, between a stage one head and a stage 2 or a 3. So would a bigger port affect any of the above or is it just more performance. Lets say i put stage one , or stage 3 heads in my car would both cruse the same??? or would teh stage 3 head be a chopier, less durable ride.??
LS1TECH Sponsor
I would think that the cam selection based on the head flow would make a bigger difference. Why get a better flowing head if you don't have the cam to take advantage of the flow? Do you have a cam in mind?
Originally Posted by MUSTANGEATER
There's no uniformity among Head Porters so someone's stage 1 maybe someone's stage 2 and vice versa. Best bet is to call the porter you wanted to talk to and find out what they think.
ok,here's my theory.small ports have more velocity than a bigger port,all else being equal.like steve said,you have to match the cam to what the head will flow.if your going to spin your motor no higher than 6000rpms,(with a small cam)a bigger port will not fill the cylinders as well as a smaller port with more velocity.but with a big cam, spinning the motor up to 7000 or so,than the bigger port will work better at the higher rpms,but flow will be a little lazy at the low range.it's a little over simplified,but it's my theory.
LS1TECH Sponsor
I agree with 66deuce. Port velocity is very important. A bigger port will not have the velocity of a smaller port with your cam.
Over simplified, but think of a garden hose and a 10" sewer pipe both limited with the same restriction at the end (cam and valve size). The garden hose will have much more velocity of flow than the sewer pipe.
Originally Posted by zamboxl
oooooo so basically if i iam not going to be reving into v tech territorry a big port job won't really be the best??? so with a 224, 224 cam with a factory rev limiter a medium port job will work better than a large one???
