Head Gasket for 6.0L heads on a 5.7 block?
Old 11-17-2004, 06:03 PM
Hugger's Avatar
Default Head Gasket for 6.0L heads on a 5.7 block?
The heads are 317 castings and are going to be milled .035". The block is stock size. Which GM head gaskets should I use; the 5.7's or the 6.0's?
Thanks
Josh
Old 11-17-2004, 06:27 PM
777's Avatar
umm i would think that you would be able to use 6.0l gaskets as they are for a larger bore engine...i'll let someone else clear that up for you...
Old 11-17-2004, 08:03 PM
Hugger's Avatar
anyone know for sure?
y2khawk's Avatar
6.0L gaskets
or they will hang into the combustion chamber on the head side
[EDIT]
yes, i know for sure. That's what i have run for the last 2 years.
Old 11-17-2004, 10:00 PM
Hugger's Avatar
thanks harlan!
Old 05-05-2005, 12:53 PM
Ed Blown Vert's Avatar
Originally Posted by y2khawk
6.0L gaskets
[EDIT]
Anyone know the GM part number for the stock 6.0L head gasket?
Old 05-05-2005, 03:19 PM
JZ'sTA's Avatar
Fel pro told me they were the same part number
Old 05-05-2005, 04:27 PM
y2khawk's Avatar
12589227
