60 cc heads.....what compression is that?
Re: 60 cc heads.....what compression is that?
I may be wrong in saying this because I haven't done alot of research on this but aren't the stockers 60cc? They aren't far off if they are different. I believe 6.0's are 67cc so the stockers are smaller just not sure exactly how much
Moderator
60cc? Can anyone confirm this? What if you milled them .030, then what do you get? What is the thickness of a stock head gasket? .060?
I thought that the stock LS1 heads were 70, the LS6 heads were 67 and the 60cc combustion chamber that your talking about is a milled set of LS6 heads. If you look at the SLP heads (not to buy or anything) but it says that the have been milled to make a 64cc chamber.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by stang killer:
<strong>I thought that the stock LS1 heads were 70, the LS6 heads were 67 and the 60cc combustion chamber that your talking about is a milled set of LS6 heads. If you look at the SLP heads (not to buy or anything) but it says that the have been milled to make a 64cc chamber.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Just do a search on this. All the info is on this board <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
11.03:1 with 60 cc chambers. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Compressed stock head gasket thickness is 1.33 mm or 0.0524".
Stock LS1 chambers: ~67.3cc
Eric
Eric
