Tr 220
Old 11-21-2004, 06:24 PM
slow98Z's Avatar
Default Tr 220
What kind of rwhp and torque does this cam make on a boltons car?Should I go 112 or 114 lsa?Will a 3000 TCI be ok with this cam?
Old 11-21-2004, 07:08 PM
MachoCamacho's Avatar
what are you lookin for? 112 will have a little bit of a lope but will show more power, 114 will have very little lope and show extra gains over stock, both should be fine with that stall, if i were you i'd just go 224 but thats me.
Old 11-21-2004, 07:37 PM
Gary98Z's Avatar
I would guess a cam only tr220 A4 would do around 330-350rwhp or so, although some of the M6 guys with this cam only have done 380rwhp. 112 and 114 will give the same power, just at different rpms. The 114 is supposed to idle better for automatics, but with this small of a cam, if you have a good tuner, he will be able to get it to idle well with either lsa you choose.
Gary
Old 11-21-2004, 08:03 PM
slow98Z's Avatar
my 98a4 already makes 334rwhp and 342rwtq.
Old 11-21-2004, 08:07 PM
Zeta's Avatar
I compared many TR 224 dynos vs the 220, and the 220 has a higher torque curve below 3500 or so. At the 224 has more peak HP.
I am an M6 owner, and I make well over 400 and 400 at the tire [with an LS1 with bolt ons]. The TR 220/114 works for me.
[Edited for clarity]
Old 11-22-2004, 04:10 PM
z98
z98's Avatar
400/400 with a bolt on LS1?
Unless you're saying you have a TR220, in which case you don't have a bolt on LS1.
Did you mean you have a TR220 and bolt ons?
I think that's what you're saying.
This is a great cam, they come up on the for sale forum in the $200 range. This or a B1 cam would make a great daily driver cam with a nice boost over stock.
Old 11-22-2004, 08:21 PM
Zeta's Avatar
That is what I am saying
Old 11-22-2004, 11:40 PM
CaptUSA's Avatar
Most guys will tell you to stick with the higher lobe seperation on an automatic car. I did a million man hours of research on mine, and ended up w/ a 115 lsa cam actually. **cheap plug alert** Actually, I'm selling a brand new 215/220 115 cam now. Guys at TR say it doesn't require a tune in an A4 car. It's what sold me. The converter you're choosing would be what I'd go with also. It's a good choice for a daily driver. You're still going to need traction though!!!
Good luck on your ride.
Old 11-23-2004, 11:37 AM
Spellbound's Avatar
01 WS-6, Bolt ons, TR 220 and a ST3500....It ran consistent 11.80's with slicks. FWIW
Old 11-23-2004, 12:07 PM
Silver_Whistler's Avatar
you should make well over 340 horse with a good tune. there is a guy in the truck section with headers, underdrive pulleys, cold air intake, and the tr220 cam and he made 340 rwhp in a 5.3. thunder tuned it for him and they said it still had about ten horse they could pull out of it. if you get a quality tune, i yhink you will be very pleased with that cam.
Old 11-24-2004, 04:16 PM
slow98Z's Avatar
Anyone Else
Old 11-25-2004, 04:48 PM
z98
z98's Avatar
check the dyno section, or refer to the search button
