388 all bore = fun....
that pretty much says it all.......
I'm still working out the Speed Density tune (I am WAYYYYYYYYYY rich at WOT......say....10.5:1 - 11.5:1 air/fuel ) but all I can say is "I LOVE THIS SETUP!!!!!!!!!!!!!!!" From idle to ~ 3500 it's kind of like my old 346 with the TR224/112LSA on roids (it's "quick") but by the time it hits 4500 my eyes go BIIIIIIIIGGGGGGGGGGGGGGG and I turn white (it still scares me) with how hard it pulls......."IT F*ING ROCKS!!!!!!!!!!"
in final......me = happy....
Originally Posted by z28kid98
i love my 382 down on power i think to where others are. i'm anxious to see where your numbers end up and compare them to mine. That can be the true test. I was an M6 too, and through a 10bolt, but heavy tires.
Chris
Chris
I would like to see what we compare at also (probubly dyno it around Christmas).......
I'm an M6 through a 10 bolt and through 295/30/18 Drag Radials.......so we should be pretty close on drivetrain loss....what flywheel do you have (I have an aluminum)...
Originally Posted by Mike2002
This is the same setup i am looking to run with my D1sc. What kind of rotating assembly did you use? Fuel system etc? Stock block?
i have the spec billet steel one. dynoed with 325/50/15 DR's. and a 78mm LSX intake with stock TB though.
Chris
Chris
382 AB
242/250 612/619 114lsa
Kook's 1 7/8"
True duals w/ x-pipe through moroso spiral flos
LSX 78
stock TB
MTI lid
put down peak of a little under 460hp and a little over 430 torque
i was hoping for quite a bit more, atleast 500hp, but we'll see what the heads flow and if there can be any improvement on that and then match a cam to it instead of the generic grind that is in there.
Going TH400 though, so things will be quite different
Kook's 1 7/8"
LSX 78
stock TB
MTI lid
382 AB
Kook's 1 7/8"
LSX 78
stock TB
MTI lid
Kook's 1 7/8"
LSX 78
stock TB
MTI lid
well thats good to know........I'm hoping to make 475-500 rwhp with my solid roller 244/249 0.644/0.644 112LSA cam.......I just don't know how "bad" the 1-3/4" Hookers are going to hold me back.......
I know there is more HP to be had with a better intake system as I am not seeing atmospheric pressure at WOT (the air filter/TB/etc. can't flow enough to keep up with the engine).....
Damn nice setup man and if you ever get used to it your only a crank away from 427 + lol . Grats man!! I sometimes wish I would have done an all bore aluminum 383 cause this damn iron block is heavy as hell.
Yep.....I can even keep the pistons I have. By using the 6.300" rod I used an off the shelf 4.131 bore piston that is designed to go in a "427" rotating assembly........though I would probably need to re-hone the cylinder to rid myself of the wear pattern......in reality though, when I get tired of how it runs now (HP level) I'll just spray it, I like the fast rev up this short stroke/long rod combo has to go mess with it...........
Originally Posted by 99BackNBlackZ28
On the real though, Chris' car is ******* sick! If I had the $$$ to spend, I'd love to do something similar, but for now Ill just have to stick w/what I've got.
just spray dude....easy HP.....
