Stroker guys inside..... Oil consumption Q+A within
Doing a lil research here with multiple setups.... Please post up the following info.
cubes
stroke/bore
intake(LS6, BBK, sheet metal, etc)
heads(supplier)
shop who built your setup(not NEEDED, optional)
average miles driven
average oil consumed
smoke... decel/accel etc etc
Just looking to see if different setups eat more oil than others and determine any trend in possible causes.
Thanks guys!!
cubes
stroke/bore
heads(supplier)
Thanks guys!!
Mine was using oil but we think (hope) it was the valve seals other wise it used quite a bit of oil. Texas Speed changed them for me and we they will be getting it going next week.
Shorty Director
cubes-->408ci
stroke/bore--->4.030x4.00
intake(LS6, BBK, sheet metal, etc)-->LSX
heads(supplier)--->FMS/Meaux 6.0L Stage III
shop who built your setup(not NEEDED, optional)-->Futral Motorsports
average miles driven--->100 miles a week
average oil consumed--->change oil ever 3000 miles. If I do not race I do not have to add a half a quart after 2000 miles.
smoke... decel/accel etc etc---->I have noticed smoke on accel when I have bad gas Good gas no issues.
cubes=383 10.5:1
stroke/bore= 6.125/3.905
intake(LS6, BBK, sheet metal, etc)= 90mm LSX
heads(supplier)=Rapid Stage 2 LS1 66cc
shop who built your setup(not NEEDED, optional)=Me
average miles driven=600/month
average oil consumed=1qt/3k miles
smoke... decel/accel etc etc=only a little black smoke when it loads up after putzing around for a while...one quick shot and it gets blown out.
Motor runs like a champ with no issues!
cubes=422ci
stroke/bore= 4.075x4.060
intake(LS6, BBK, sheet metal, etc)=LS6
heads(supplier)=ARE/WestCoast Cylinders 5.3L
shop who built your setup(not NEEDED, optional)=Me and a friend.
average miles driven=4k on the motor (40%street/60%drag racing)
average oil consumed= 1 quart/1k miles
smoke... decel/accel etc etc= not much smoke on accel/ none on decel
cubes: 383 iron truck block
stroke/bore: 4.00 / 3.905, Eagle rotating assy
intake(LS6, BBK, sheet metal, etc): LM7 truck intake with 6.0L injectors
heads(supplier): #241 LS1, 3 angle grind, port/polish
shop who built your setup(not NEEDED, optional): DIY/home, machine shop Edwards Engines
average miles driven: 300 miles per week
average oil consumed: 1 quart between changes due to drip from rear crank seal
smoke... decel/accel etc etc: none
stroke/bore: 4"/3.905'
intake(LS6, BBK, sheet metal, etc): ls6
heads(supplier): tea 5.3l Stage2
shop who built your setup(not NEEDED, optional): HPE
average miles driven: just put the first 5 miles on it
average oil consumed: don't know yet
There seems to be a rumor that stoker engines consume oil. This is just not true. If it was properly built, the gaps set properly, seals are sealing ang gasktes are good, it should consume none to very little oil
cubes: 383 LS6 Aluminum Block
stroke/bore: 4.00 / 3.905, Lunati 4340 forged crank, Wesico forged reverse domes
intake(LS6, BBK, sheet metal, etc): LS6
heads(supplier): MTI 2R LS1 Heads
shop who built your setup(not NEEDED, optional): MTI
average miles driven: 200-400 miles a month, not driven below 50 degrees
average oil consumed: 1 quart every 500 miles under strip and also street conditions. Oil is changed prior every trip to the track. Engine hasn't seen over 500 miles on an oil change. I use a PF59 Delco filter and 6 quarts of Castrol GTX 10w-30.
smoke... decel/accel etc etc: none, a normal engine load up smoke in certain conditions.
cubes: 427
stroke/bore: 4.0/4.125
intake: LS6 first, now a FAST 90MM
heads: TEA
shop who built your setup: More Performance
average miles driven: about 7000/year
average oil consumed: 1 quart every tank of gas (between 100 and 250 miles depending on highway or track driving)
smoke: smokes on startup but I can't say if it smokes on accel/decel. I put a metco breather on the oil fill spout about a month ago but haven't noticed a difference in oil consumption. Compression/leakdown test are planned. The heads have about 5000 miles on them and the rest of the motor has about 19000 miles on it. It used oil before the new heads were installed. New heads didn't change anything. Originally I had to put a quart in every 1000 miles and it has steadily got worse. If it needs new rings I'll take it back to More, they've been a good shop to deal with. Also, there is no oil whatsoever under the car. It's not leaking.
heads: TEA
cubes--- 383
stroke/bore----4.0/3.905
intake---LS6
heads(supplier)--- stock, locally ported
shop who built your setup----local motor builder
average miles driven--500/week
average oil consumed --- 1 quart the first 2000 miles
smoke... decel/accel---minimal, if any smoke when stomping on it.
intake---LS6
