Conflicting info from DTD and Boyd Coddington?
Old 11-30-2004, 09:25 PM
John02SS's Avatar
Default Conflicting info from DTD and Boyd Coddington?
I'm in the process of ordering a set of Boyd Timeless 2's and DTD has told me the best offset is no more than 40mm while Boyd Coddington told me that 20-25mm is what I'm looking for a 17x8. Any input from the offset guys is appreciated. I spoke to a few on the board already and 25-35 seems to be the norm. I want the 17x8 to sit flush like a 45mm 17x9.5 does. Thanks.
John
Old 11-30-2004, 10:13 PM
John02SS's Avatar
Hoping Todd will pop in and help me out. I'm ready to order them from DTD as soon as I get the offset issue figured out.
Old 12-01-2004, 10:19 AM
Shane's Avatar
[edit] Yo, Todd is the expert, so I'm gonna remove my incorrect post so there's no confusion...
Good luck - the Timeless 2 wheels rock! (see sig)
Old 12-01-2004, 11:29 AM
Todd@AZPowerAndSound's Avatar
lets keep it around +40. Stock was a 8" rim with a 55 offset, so with another 8 and +40 offset you are coming out another .6" from stock. Good look without going overboard.
Old 12-01-2004, 04:46 PM
John02SS's Avatar
Shane,
Car looks GREAT!!!! The timeless 2 is pretty rare!
Todd,
Thanks buddy! I really appreciate it. Any suggestions on getting someone to call me back so i can order them? JK Does Kevin still work with you guys? I couldn't get his name to come up in the company directory.
Old 12-01-2004, 04:55 PM
just dial the retail que...we have 20+ retail guys, the call will be answered. Or dial 424 for Jim right now hes available
Old 12-01-2004, 06:41 PM
John02SS's Avatar
How would a 8 inch wheel with the 40mm offset compare to a 9.5 with a 45 offset. How much does the width of the wheel play in where the tire will set in regards to the fender. I appreciate the help Todd!
Old 12-02-2004, 12:09 AM
John02SS's Avatar
This is how I want the front to sit. It is a 45mm offset 9.5 wheel. Will a 40mm on a 8 inch wheel look like this in regards to position to the fender edge Todd? Thanks.
http://img.photobucket.com/albums/v3...s/P7170130.jpg
Old 12-02-2004, 02:03 AM
the predator's Avatar
Shane-your TA looks killer. im jealous. i think i may purchase the timeless 2s sometime in the near future.
Old 12-02-2004, 08:49 AM
Shane's Avatar
Thanks for the compliments guys... I (obviously) love the look of the Timeless 2 - not too flashy, but not too common either...
Old 12-02-2004, 05:05 PM
FigsZ28's Avatar
Shane what is the offsets on your wheels?? Im looking at the exact setup. Thanks for any info in advance
Old 12-03-2004, 08:44 AM
Xsta Z 28's Avatar
Exclamation
If I'm doing my math correctly, to have the outside face of an 8" wide wheel to look identical to a 9.5" wide wheel with a 45 mm offset, the offset of the 8" wide wheel would be 26 mm . . .
To attempt to explain without a picture. An 8" wide wheel is 1.5" narrower than a 9.5" wide wheel (duh?) So from the center line of the wheel, the face of an 8" wheel is .75" further "into" the wheel well, if the wheels have identical offsets (since offset is the distance from the center line of the wheel to the back of the lug mounting surface). So to get the 8" wheel in the same position as the 9.5" wide wheel it needs to move outwards .75" or 19 mm. So 45 mm minus 19 mm equals 26 mm offset.
Old 12-03-2004, 08:58 AM
Shane's Avatar
56mm 17x9.5 up front
50mm 17x11 out back
I have to run spacers up front to clear my big brake kit, but I assume they'd be fine with the stock brakes.
Old 12-03-2004, 10:44 PM
John02SS's Avatar
Xsta,
That is what I came up with along with the guy at Boyd. I guess different people have different opinions than some on wheels fitment. I'm stuck! lol I don't want to do a wheel that will not sit flush, but don't want to go too drastic either. Just not many 17x8's out there to judge by.
Old 12-04-2004, 09:11 PM
John02SS's Avatar
I give up! I'm just gonna order 9.5's with a 45mm offset and be done! I just can't spend that kinda money and take the chance of not liking the way the wheel sits. I'll be sure to post pics when I get them installed!
Old 12-04-2004, 09:41 PM
skewba98z28's Avatar
Man you'll be a lot happier with the 9.5's anyways 8 is just to narrow on a f-body IMO
Old 12-05-2004, 01:33 PM
SilverLS1's Avatar
i say go with the 8's......i like the skinny tire up front, gives it a "hey, im a drag car, with pimp wheels" look!
