What should i use to clean Camshaft?
Old 12-03-2004, 01:56 PM
BeeraddSS98's Avatar
Default What should i use to clean Camshaft?
i bought a used camshaft and there is some crud and grime in between each of the lobes. IM wondering if i should just let it be or clean it before my buddy puts it into my new motor. It allegedly had 300 miles on it when i bought it. Also it is made by ultradyne? Has anyone ever heard of them before?
Old 12-03-2004, 02:13 PM
conan's Avatar
brake cleaner or carb&choke cleaner should work fine
Old 12-03-2004, 02:20 PM
gotta love the quick responses. Thanks. Anyone heard of ultradyne?
Old 12-03-2004, 02:28 PM
Cefiro's Avatar
never heard of it before, what are the specs?
Old 12-03-2004, 02:30 PM
luv2spd's Avatar
I haven't heard of ultradyne. What are the specs on the cam? Yeah, you should def. clean all the crap off of it before installing it and then coat it with oil good before sliding it in.
Old 12-03-2004, 02:36 PM
The specs on the cam are as follows spec 226/226 .591/.591 lsa 112. I bought it from TA2slow346.
Old 12-03-2004, 03:06 PM
cyphur's Avatar
I've never heard of that name. Ever.
Old 12-03-2004, 03:11 PM
This doesnt make TA2slow346 look very good now does it. Maybe he just made it up. Maybe its a shitty cam with way more than 300 miles on it since there a bunch of **** between the lobes.
Old 12-03-2004, 03:41 PM
nuzee's Avatar
Ultradyne is a respected company. I can't remember if they were bought out by some other company in the past 10 yrs. Some very fast folks swear by their cams.
Old 12-03-2004, 03:43 PM
That makes me feel better. Had to listen cyphur traq tho he is a G.
Old 12-03-2004, 03:53 PM
Cstraub's Avatar
Harold Brookshire owned Ultradyne. Harold has designed lobes for most of the cam companies. He is a genius and well respected. Ultradyne was closed by Uncle Sam and the assets have been bought by Bullet Cams. Harold is now working for Luanti and his new stuff is now Voodoo Cams a division of Lunati.
No for the bad news. Harolds stuff make big power because of aggressive lobe design. . .what this means for you is it will probly be vary hard on valve springs. . .I mean very hard. You'll need to check spring pressure around every 3K miles.
Chris
Old 12-03-2004, 04:22 PM
wow..thanks for the info that is a very good thing to know.
Old 12-03-2004, 04:24 PM
Cstraub's Avatar
Your welcome.
Old 12-03-2004, 05:28 PM
cyphur's Avatar
Cool. A G, huh? LOL thats a new one.
Concerning Ultradyne, you learn something new everyday. Cstraub, that was some great info
