Will the KS w/locating tab work on 98 PCMs?
Old 12-05-2004, 10:19 AM
Scalpel's Avatar
Default Will the KS w/locating tab work on 98 PCMs?
I have a new pair of KS with the locating tab on them. Will they work with the 98 PCM when I used the correct KS harness for them? Thanks.
KS - knock sensor
Old 12-06-2004, 09:57 AM
Scalpel's Avatar
To the top.
Thanks.
Old 12-07-2004, 09:17 AM
Scalpel's Avatar
To the top!
Old 12-07-2004, 10:21 AM
John_D.'s Avatar
What is KS?
Old 12-07-2004, 10:29 AM
HumpinSS's Avatar
Knock sensor
Old 12-08-2004, 04:04 AM
Predator's Avatar
I'm 99% sure they will. I recall reading numerous posts about the '98s having a constant 4 degrees of knock retard, and part of the solution was replacing the sensors with '99 and up knock sensors.
Old 12-10-2004, 05:13 AM
98A4LS1's Avatar
Maybe some more '98 owners will chime in. Have other '98 owners switched to 1999+ knock sensors?
Old 12-10-2004, 09:31 AM
John_D.'s Avatar
I didn't switch, but I did desensitize them in hptuners... I was able to get rid of the mid-range timing retard speed bump, and take timing up all across the range.
Old 12-11-2004, 10:13 PM
dissonance's Avatar
KS - knock sensor
i have the new style sensors with the new harness and they work just like stock.
they did NOT fix my knock problem, but i think it was worth it because my stock ones had rusted...
Old 12-11-2004, 10:38 PM
Scalpel's Avatar
Thanks, Dissonance.
Old 12-11-2004, 11:31 PM
WicketMike's Avatar
i have them on my 98'
