Most hp w/stock bottem end???
Whats to most hp you can get from a stock bottem end f-body LS1. With out any power adder. Pretty much all the bolt ons mid to high 400's???
I`ve got 441rwhp and 403rwtq N/A With a 150 shot I got 650rwhp and 660rwtq. I have A4 with Vig stall and a 12-bolt! Just got to tune it right!!Car in Sig This is with a stock bottom!!!
Yea, 441N/A with A4, 12-bolt, Vig stall. We could have gotten 10rwhp with alittle more timing. Tuned for spray right now. The 12 bolt 3.73 gears eats probably 15rwhp, and if it where a 6sp you could add another 15-20rwhp. That would put you at 475-485rwhp.
I thought some shops were making near 500rwhp on 346ci w/ AFR heads and big cams on stock bottom ends. Could be wrong though so dont bash me!! Seen plenty of H/C cars with 450+rwhp on stock bottoms on the net. Most i ever got w/ my SS on stock bottom w/ TEA Heads and 224/224 cam w all the bolt-ons was 430rwhp back in july 03.
LG has done 500+RWHP on a stock bottom before (pretty aggressive set up, open headers, race gas, aggressive tune) and I know Mikey at Rapid has done 500RWHP with the "Dominator" H/C package (requires flycut pistons and recommended ARP rod bolts.)
I saw there was a Vette running the AFR 205 heads over 500RWHP also.... do a search within the last month you might find the post in this forum. In any case it will have to be a very aggressive set up with the FAST 90 Intake/TB, maybe electric water pump, the rest of the boltons, high $ Stage II LS6 heads or AFR heads and a decently large cam like the Magic Stick, G5X3-4, TRex, Dominator cam, something along those lines. Also having a M6 I would say is almost mandatory for hitting 500 on a stock bottom.
so it sounds like mid 400's is fairly easy with the right stuff and 6-speed. My whole plan was to go FI but more I look it to the H/C cars I like what I can see. Plus the money I was going to spend for a FI setup I could all the bolt on's,rims,and the hood I want. Tuff to pick what I want. I think when it's all said and done I would go faster at the track with h/c set up. Only cause I would get more for my money. This is manily street car. But I'm not **** about bad idle and all that. But it has to be pump gas and run with out stalling at every light. What kind of time you guys running in the 1/4 with mid 400hp? Say with 1.6/1.7 60's...
