Catback weld or bolt-on?
i just got in on a magnaflow GP. i was planning on bolting it in at home but a friend of mine said to have it welded in. he bought a bassani exhaust for his stang and the guy he bought it from welded it in for him cause he said that was the only way to go. is he right or does everyone just bolt it in?
Jacob
Jacob
You can weld everything except where it connects to the headers and where it goes over the axle and still get it out without dropping the axle. Welding mine actually changed the tone a bit. Made it deeper and lessened the rasp.
Originally Posted by hardtopSS
its hard to get that stuff off after its been bolted on for awhile . i had to cut mine off, even though it was bolted on.
Just tack weld if you have a good seal. That way the pipes can't shift and then later if you want to modify anything all you have to do is burn off the tacks. Use a band clap at the junction of the Y pipe and I pipe
