True duals or cut outs?
I am thinking about doing a cam, and I know the only way to get the most power out of it is run true duals with an x pipe and bullet style mufflers. I would love that sound, but I've already been getting complaints about just my loudmouth exhaust. With true duals and a cam, I will probably do the G5X3 cam, my motto is go big or go home, and if Im going to spend all this money and time putting a cam in, I might as well try to go as fast as possible with it. My question is, which is better, true duals or two cutouts after each header as far as power goes? I am looking to quiet the car down as much as possible, for a more stealth and for people complaining so much. So is there any real difference with cutouts vs true duals? If not, I can put stock cats and muffler on the car and run two electric cutouts and whenever I want to race, simply open them up, but when im coming home late one night, I can have them closed and not wake up the neighborhood, yet still maintain the same power. Thanks for any help.
IMO, the loudmouth exhaust is the loudest there is. I had TD's with bullets and hated it. I went back to a catback. If you do duals, get the borla XR1's. They simply rock.
In regards to power, I don't know for sure, but I believe you will pick up more from having the duals then just straight cutouts. I love the way my car sounds now. It perfect.
IMO: if it is a daily driver and you would like a quiet vehicle at times, go with the dual cutouts.
It is true, that you probably wont see quite the gains, but they are probably minimal and when calculating risk vs benefit (the risk being hearing loss, headache, etc. While, benefit would be relaxing while you drive, not pissing the neighbors off all the time, not having cops up your *** all the time, not having that loud highway drone at 1800 rpm's on a long drive, etc). I think you would benefit more with the cutouts.
Now if it was not a daily driver, I would put the TD's on in a heart beat and never look back.
This is all just some opinions I have developed over the period of time i have had my loudmouth/ORY/mild cam setup.
Well it looks like I will probably go with dual cut outs, I will get some cats and a stock muffler maybe to give my car a sleeper look. I'm assuming there isn't more then a 5-10rwhp difference, if that, nothing too drastic and I can deal with a little bit less power if it saves me from getting tickets and complaints etc. Thanks for the replies.
Get true duals. They sound absolutely awsome and make more power, especially torque and power under the curve. As for volume, they aren't all THAT loud. There was a minimal difference between stock plus loudmouth and LT's/no cats/duals on mine when I installed the headers/duals. I coudn't even tell you which setup was louder.
Your saying true duals are about as loud as the loudmouth? True duals would be cheapier, if I went with the TSP truel duals. I really would like to go with borla XR1 mufflers, I love the sound of borla, but they are a bit pricey and a little bigger so I would have less ground clearance. I guess when I go to do a cam, I'll try out the true duals with XR1 mufflers and see how that is, and if its too loud, then I can easily sell it and go to a quieter setup. I guess my mind changed again, damn trying to decide on what mods to do is sooo hard!!!!
Here is a clip of my car with the Borlas. All was done with 3" and you can tell how much clearance I have on a lowered car. I don't hit anything.
True Duals
IMO, TSP is not that loud, i have a stock cam as of now. Like everyone has said, you will lose a little hps with the cat back. The true duals are loud, yes, but i dont think they are as loud as the loudmouth exhaust. But, i have heard that many people once having a cam makes the true duals much louder. Just depends on what sound you like i guess.
Originally Posted by blkZ28spt
I vote for true duals. (almost always do, lol). Yes, that is correct, I am saying that stock plus loudmouth has a volume comparable to LT's/duals with no cats.
Im happy with my duals. Look in sig. Sound files are on LS1sounds. They are quieter and sound better that my LTs ORY and open cutout. Very clean and not obnoxious. No drone inside either.
My car is just as loud as loud mouth, only deeper and more agressive. If there is a way to fab the XR1's where my thunders are, and have it be quited, it might do it.
Originally Posted by Black02SS
I will disagree to an extent. Depending on the mufflers you choose, the volume will change. Like I said before, with the bullets, the car was loud. Since I went to the borlas, it is much smoother and more mellow. Little bit deeper then my Hooker Catback was.
I was wondering, has anyone done duals over the axle, with the mufflers behind the axle, and electric cutouts behind the X-pipe? Would this even be possible? It would basically be like running a full dual exhaust all the time (put quiet mufflers on if you want to even) and then you could have dumps after an X-pipe (to get the scavenging effect and more power) without going through mufflers.
So it would go:
Headers
Pipe
X-pipe
Dual electric cutouts
Pipe over axle
Mufflers
Tips
Is this possible? My reasoning is that I already have one 3" Streetpro cutout, and I could get a second for the other side and still run duals over the axle that are quiet on the street. Would the cutouts add any power?
So it would go:
Headers
Pipe
X-pipe
Pipe over axle
Mufflers
Tips
Originally Posted by nharrison02ss
I vote for both. Just do what I plan to do. Put dual cutouts after each header and then run true duals, therefore if if is not loud enough open the plates.........Whatever you do get the electric cutouts their bad as hell!!
Originally Posted by BLASTER
I'd like to do the E-cutouts after my X but it would be tight. If Streetpro made them in stainless I'dhave them already but they don't.
Heck with that, gotta put them before the X, as close to the collector as physically possible.
