Sponsor Sales & Specials - TTP A-K Stage 3 T56 Transmissions
View Full Version : TTP A-K Stage 3 T56 Transmissions
TTPMatt
12-14-2004, 01:03 PM
Available for the Y-Bodies and F-Bodies. Tremec T56 017, 020, 023 models.
You provide the transmission core (Or we can provide it for a surcharge). All parts listed are brand new replacement pieces.
Carbon Fiber Synchronizer Rings
3/4 Steel Shift Fork
Shift Pads
Flushed, Cleaned, Assembled
$950.00
We will remove and reinstall your transmission on site for only $300 (Add $150 for Corvettes) when you purchase one of our A-K builds. We will also install a new clutch/flywheel for no additional flywheel.
The transmission builds do not include replacement of gears/synchro assemblies. Upon inspection of the unit we can diagnose any other problems you may have.
All of our A-K S3 transmissions come with a limited 1 Year/12,000 Mile warranty.
Give us a call at 973-340-4069.
SPANKY LS1
12-14-2004, 01:57 PM
I'm assuming thats labor/parts only, its using our core/existing transmission, correct? Thanks, Shawn
TTPMatt
12-14-2004, 03:19 PM
That is parts and labor only. It is using your core.
BLASTER
12-14-2004, 09:53 PM
Hey Matt.
What is the turnaround on the build and install? Do you actually rebuild ours or just take it as a core? I have a leaky rear main seal and possibly a bad 1-2 syncro so I may need/want to go this route if I don't have any luck with the dealer. Thanks
TTPMatt
12-15-2004, 08:35 AM
We rebuild yours. We inspect all units if there is any other bad parts, i.e. gear/synchro sleeves/etc. we can inform the customer and see if they would like to replace that also. There is no additional labor on changing gears/etc.
Turnaround time is 2-3 days.
DONAIMIAN
12-15-2004, 02:51 PM
Whats the price of one of these out right with not core, also the price on one with all new syncros.
TTPMatt
12-16-2004, 11:32 AM
Outright with no core it is $2395.00 fully built with all brand new gears, syncho assemblies, syncho rings, shift pads, shift forks, input/output shafts, etc.
With rebuilding a unit with brand new synchro assemblies (1-2, 3-4, 5-6, Rev) it would be another $425.00 for these assemblies. No additional labor.
Nate_Taufer
12-16-2004, 01:56 PM
how strong are the units with brand new synchros?
DONAIMIAN
12-16-2004, 02:21 PM
thats not a bad deal at all
TTPMatt
12-16-2004, 04:11 PM
Estimated FWTQ handling is 700 on our brand new units.
Given that the transmission is in excellent condition with our normal A-K build it should hold that power.
- Matt
BLASTER
12-16-2004, 06:03 PM
Hey Matt,
Left you a VM yesterday. Please excuse my ignorance. Are the synchros you use different/better/stronger than the stock ones? I think I need a new 1-2 synchro and hell i'll just get them all replaced if it is an upgrade. I'll do the clutch too. Dealers are being assholes about my headers and duals.
LS1POWER98
12-17-2004, 11:09 AM
12000 miles 1 year warranty thats it!!!
that dont sound to good
it should be lifetime warranty
its like you guys arent sure of your product
if it was a lifetime warranty or 100,000 mile id buy 1 and maybe 2 one for a buddy
TTPMatt
12-17-2004, 11:24 AM
LS1Power: Look at most of the transmission companies that build performance units, they all offer 1 year /12000 mile warranty. The problem with putting a warranty on the transmissions is that even when the unit is abused/misused the tranny builder still takes the heat.
Nate_Taufer
12-17-2004, 09:31 PM
yeah man, and that probably excludes racing em, like im sure no one is gonna race with these, right? hehehehe
07BlueDevilZ06
12-18-2004, 07:22 AM
to the top
