Deep pan, filter upgrade?
There is a factory deep pan that is used on GM trucks. Pick up about 1 quart additional capacity.
Part # pan 24229658 $38.41
Part# filter/gasket 24208576 $31.38
Both are available through an AC-Delco warehouse or GM dealer. The pricing reflects what you should be able to buy it for through an AC-Delco warehouse. The pan may have a drain plug as well. I'll be able to find out if it does by Monday.
GM Parts Direct sells as well
24229658 $38.37
24208576 $32.98
24229658 $38.37
24208576 $32.98
The above posts are correct. If you use the GM deep pan, you'll need the OEM "deep" filter. The deep pans no longer come with drainplugs, unless where you buy it from has old stock.
If you buy an aftermarket deep pan, you'll need to use a stock filter unless otherwise specified from the instructions.
What is the difference between deep pan filters and shallow pan filters?
If I run a stock filter with my deep pan, will I run into any trouble?
Originally Posted by RevGTO
The reports I've read on this forum have said that the deep pan only keeps the fluid about 2 degrees cooler on average. If that's the case, why would anyone bother?
