H/C guys! What MAF are you running?
Been using the Pace descreened 85mm LS6 MAF since my stocker died at 10K miles. It's calibrated for the LS1 and I have had no issues related to the MAF. In fact when my factory one bit the dust it was recommended to me by Mikey owner of Rapid Motorsports.
Also I hear ALOT about screen no screen??? I know the screen straightens the air but I hear it is not recomended for street use? Do I need any special bellows or anything if I go to a 85 mm MAF? Im having trouble getting the car tuned with this MAF The car has lost at least 20 ft lbs of torque and should be putting out 10-20 more rwhp! Just wonder if the maf could be part of the problem? I asked in the tunning section and got no replys.
Sounds like there is definitely a maf problem.
It will be easier to tune with a stocker.
Taking the screen out or porting the ends will make it read differently. A good tuner can probably work around it.
A new stock maf would be more than enough, getting a bigger one won't make it run any stronger.
If you're intent on a bigger one, just get the corresponding maf table for it, and the tuning should fall right in line. (one of the z06 pieces, screened or unscreened)
