oem y2k wheels on WS6
Old 01-01-2005, 05:46 PM
SVC707's Avatar
Default oem y2k wheels on WS6
What exactly will i have to do to get these wheels to fit perfectly on my car. they are of a 2000 vette so they have the vette's offset. what spacers/adapters do i need.
thanks Steve
Old 01-03-2005, 08:02 AM
Xsta Z 28's Avatar
From the information I have, the fronts area 56 mm offset. Techincally they should bolt right up, althouugh may appeara bit "tucked" in. So you can more than likely run a 1/2" spcare with new lug studs for the right look.
The rears area 65 mm offset, now these are not going to mount up, with out some big inner wheel well mods. A 3/4" to a 1" adapter could be run to get the wheels to look good in the wheel well.
Old 01-03-2005, 07:21 PM
Aaron's 00 TA's Avatar
I was running 18x9.5's with the 65mm offset and they mount up just fine. I did need to "massage" an area about the size of an inch on the inner rear wheel well, where my tire would rub when cornering. I have some pics in this thread to see what they look like:
https://ls1tech.com/forums/wheels-tires/207992-my-t-chrome-18x9-5-y2k-s-new-rear-filler-panel.html
Old 01-03-2005, 07:36 PM
SVC707's Avatar
https://ls1tech.com/forums/showthread.php?t=207992
yours fit because it wasnt lowerd, unlike my situation.
who knows where i can get these adapters to push out the rear 1", again adapters not spacers
Old 01-04-2005, 09:37 AM
777's Avatar
skulte.com
Old 01-04-2005, 08:47 PM
jonnyc's Avatar
what you want are the 25mm adaptors from h&r springs.i got mine from livermoreperformance.com.they aren't cheap($125 for two)but they are very high quality and you won't have any problems with them.i've had mine for almost 3 years now and have done 6 open track days(roadracing) and about 12 passes at the strip and never have any problems.i am running 18x9.5 with sportline springs and the vette offset and i had to roll the rear finder just a little beacause with 2 people and a hard bump it would rub on the passanger side.pm me your email address and i'll send you some pics so you can get an idea of how it will look.
Old 01-04-2005, 08:56 PM
SVC707's Avatar
great if you can show me pictures of the wheels on the car where they mount and shots of the body
Old 01-04-2005, 10:15 PM
ritz's Avatar
That's a high offset...is that the stock Vette offset? The ones on ebay from oe wheels has an offset of 56MM in the rear.
Would these adapters work on a wheel that has a 56MM offset. Say 18x9.5 Y2K C5's?
Old 01-05-2005, 04:37 PM
Xsta Z 28's Avatar
I'd only run a 18 mm spacer max with a 56 mm wheel . . .
