Milling & Compression Ratios
Old 01-04-2005, 12:59 PM
Juiced's Avatar
Default Milling & Compression Ratios
How many thousanths are equal to a cc, if i have 73cc heads and want to get 11:1 compression with 2cc valve reliefs .050 gasket and pistons .008 out of the hole how much would i have to mill them.
Old 01-04-2005, 01:02 PM
xfactor_pitbulls's Avatar
https://ls1tech.com/forums/advanced-engineering-tech/111207-ls1-head-combustion-chamber-cc-volume-vs-cr.html
Check there, all the info you will need. However that big a chamber to get that compression ratio is a stretch. What heads are you starting with?
Brandon
Old 01-04-2005, 01:23 PM
Juiced's Avatar
those are finished chambers after the 2.08 intake and 1.6 exhaust valves.
Old 01-04-2005, 01:27 PM
Bo White's Avatar
What I have personally seen is for every .006" you take off the head you remove 1cc out of the combustion chamber.
Old 01-04-2005, 01:36 PM
Juiced's Avatar
so with the following specs i should get 10.7:1 compression
Milled .040
67cc chamber
.050 gasket
1.5 cc valve reliefs
