Could I have bent my valve?
I was changin my springs today and on cylinder number 5 the valve stem got caught under the retainer and I turned down on it a couple turns. I am using the crane cams valve spring tool. I probably only turned the ratchet a few times as I was watching to see if it would come up through the retainer or not...I then realized it was off more than I thought and was under the retainer.
I am paranoid as hell right now...will someone give me some advise please???
It was the tdc method. Their wasnt any more load on the ratchet than I would notice than when pushing the springs down normally. It is not even hard at all to push the springs down with this tool...maybe like 5 ft pounds to turn the ratchet. I am thinking I would have noticed it getting harder to turn if I was bending the valve...are they really soft and easily bent?
I had some cotton rope crammed in the hole but dont know if I had enough in it to catch the valve or not...so I dont know if this saved me.
So what should I look for?
Will I just hear air hissing out of the head in that valve or what?
It was also the valve on the left. Is this intake or exhaust? If so...which one is a larger diameter? Hoping it is the smaller one so that it might not have gotten down to the piston. The edge of the bigger one would hit sooner...I would guess.
