Fast 90 Vs TPIS oval 90 LS6
Does anyone have and info on comparing rwhp and rwtq or track times of the two intakes on a stock cubes ls1or ls6 motor?
What one do think will make better ET on stock cubes?
Both of them move a ton of air, I would seriously doubt you could find any notable difference in performance between them. I went with TPIS strictly because of the problems I've heard about with FAST.
Originally Posted by speedracer5532
But you are using the TPIS 90mm TB on the 90mm Fast intake not the TPIS mod to the LS6 intake with the oval TPIS TB correct?
Originally Posted by J-Rod
I tested both on a max effort H/C car. The Fast 90 made more HP than the TPIS up top (around 10HP up top).
6600 rpm clutch dump of death Administrator
J-Rod, how did the Fast 90 intake compare with the TPIS Oval LS6 on low end torque? Which intake do you think will give the quickest ET?
They were both the same as an Ls6 until you go to the upper RPMs, and then they both pull away. You gave up nothing on the bottom with a FAST.
The FAST was ~+10 on HP and TQ over the TPIS modified LS6 intake....
