What will safley get me into the 10s Details inside
This is motor wise.... i wish have the rest of the drivetrain soon enoght
393 ALl bore a lil stroke 11to1 with a 5.7 head
my question is what cam and what heads whould get me there in a almost full weight car with a 4400 stall and 4.10s out back
Shouldn't take too much. I'm shooting for it with home ported heads and a very large cam, for stock displacement anyway. You will need steep steep gears and a very good suspension though. Good luck and keep us posted.
Check out the new LSK lobes from comp, they will help but deffinately need an agressive spring as they make the XE-R lobes look like sissys. With a big bore like you have they will probably really help but will require a stout valve train. Do a search on them under my name and you will find a posting about all the available or you could look in comp's new master catalog.
The 393 was my last motor, that I grenaded. All bore 4.100 X 3.72 (offset ground crank).
ARE stage 2 heads, 232 236 cam, .600 lift, 112 ls.
With a nitrous tune (lowered timing), heavy driveshaft, 400T, 12 bolt, the car ran a 11.1 on just motor. Would have been a 10 with better timing and setting up the suspension for all motor. Car weighed around 3450
The cam was extremely small, because it was a street car. But put down 420 HP with slicks on the car.
Overall, it was a good motor. But you'd be better off getting the Eagle crank & throw that in there, unless you are racing in a specific class that limits displacement. I found myself wishing that I had just waited until I could afford the better crank.
