Lightweight battery vs battery in trunk?
What is recommended?
Lightweight battery, or a full size battery mounted in the trunk? Ive heard that lightweight batteries cant start the car from the trunk.
Whats everyone here using?
i did red top optima and polished box in spare tire well and flaming river long rod switch thru the rail light !!! Clean and i def noticed a increase in traction
Motorboater
JS, explain why I should have put it in the right side.
These cars already naturally slam that side down in the launch and twist the car through the 60 foot...adding a bunch more weight over there will only compund that problem.
I put my battery on drivers side a couple years ago and immediately noticed the car launching much more evenly. I do not nor have ever needed airbags like so many other folks to keep the car level, been a pretty neat trick for me so far that alot of other folks that have seen the car have done as well..took a good bit more work to make that box and everything fit over there and still be able to put my t tops in but it was worth it.
11 & 7 Second Clubs
Motorboater
i think its a matter of first logic and convenience for folks. there is alot more room to put a battery over there and you don't need as much wire since you're running up to the passenger side of the engine compartment with it.
all i know is it has worked well for me.
bickel i hope you're kidding if you are saying it isn't worth the couple hours of time and bit of coin it takes to take all that weight off the nose of the car and put it back where it should be..
Originally Posted by ramairstyle00
i've also been told to switch mine to the passenger side for weight distrubution reason but don't know why
