how hard is it to take off heads and pull cam on stock LS1 engine
Old 01-11-2005, 03:22 PM
WAGE_SLAVE's Avatar
Default how hard is it to take off heads and pull cam on stock LS1 engine
what is involved in pulling off stock heads and a stock cam from a stock LS1 engine that is already out of the car. It is at a junkyard and I just needed to get a stock LS1 block
Old 01-11-2005, 03:26 PM
jrp
SN95 Director
jrp's Avatar
ls1howto.com and take what you need.
Old 01-11-2005, 03:34 PM
GTS346's Avatar
All you need is a good metric tool set.
Make sure its got 15 & 16mm sockets as well, as a fair few tool sets don't have the 15mm and theres a fair few 15mm bolts on an LS1.
What oil pan does it have?
Old 01-11-2005, 04:34 PM
Nate_Taufer's Avatar
as well as 8 and 10 mm being the other ones that are used a bunch.
Old 01-11-2005, 08:58 PM
Crazy Man's Avatar
If its already out of the car you should be able to pull it apart in about an hour or 2 max.
Old 01-11-2005, 09:23 PM
jd13's Avatar
It's not hard, just time consuming.
Old 01-11-2005, 10:05 PM
jermzz's Avatar
I did my head swap in my gerage by myself with no power tools, just the tools I got from my dad for christmas, between work and school in 3 days.
Taking everything apart is a sinch, the hardest / most time consuming part is cleaning the deck and the bolt holes
Old 01-12-2005, 10:21 AM
Richiec77's Avatar
Lots and lots of cursing. lol Oh wait the motor is out of the car.
Old 01-12-2005, 10:36 AM
goober35's Avatar
Not sure on the size but you will need a socket to get the crank bolt off so you can pull the pulley. Unless it is alread off. If you know what u are doing it should not take more than 30mins with some power tools. Just go to www.ls1howto.com this will show you how to do it in the car. If it is out is so much easer to break loose the head bolts.
Old 01-12-2005, 03:31 PM
pdd
pdd's Avatar
hey thats what was gonna say
Old 01-12-2005, 05:59 PM
HPP
HPP's Avatar
I'm looking at that site now, and it seems they are working with the engine in place but.....how?!
They say "unbolt the heads". Well, great, but have the engine is behind the windshield, so how so you reach anything?
