Can you tell me what's wrong? (video)
Here's a vid of what my car has been doing. What does it look like to you? This is one of the few times it actually started when I turned the key, it took several minutes of trying to get it to start before hand.
http://locker.uky.edu/~ebsurb2/100_0271.MOV
When the lights flicker and the guage moves like that it's usually an indication that the voltage regulator is shot. It is internal to the alternator so it looks like it's time for an alternator. Before you do that though, make sure the battery connections are clean and tight, check your grounds, and check the connectors. If all of that is good, get an alternator.
Everything he said, plus make sure your belt isn't slipping. It would have been nice to also see the tach to see if there was any surging. Do you have a low surging Idle?
http://locker.uky.edu/~ebsurb2/100_0272.MOV
Enjoy!
PS: I ordered a new Alternator today. It'll be here on monday.
Originally Posted by CANNIBAL
Powermaster sells 200 amp alternators for the LS1.
When my voltage regulator went out it did the same thign as in the posted video.
powermaster is this a brand?? where could i get one?
