Texas Speed True Duals
How Are The Td With A Lowered Car? I Am Running The Mac Springs And Qa1's And It Rides Pretty Low!!!! Right Now I Have The Slp Y Pipe Which Is The Low Point Of The Car And Am Wondering If The Td's Would Lower The Low Point????????????
I tried mine with 1.5 drop and ended up taking them off, I just did not want to scrape everything and I could not even get into my garage with them. The bullets is where I had lost most of my clearance and I thought I had them up really tight.
My car is lowered and I think my duals tuck up pretty well. I banged in my drive shaft tunnel a bit and ground down an edge of my tranny cross brace. I have not scraped yet, but understand that I don't carry around "large" passengers or loads. I also bought an aftermarket toque arm. That one mod gave me much needed room to tuck it up even more. I am going to install some tubular sub frames, so that if I do scrape, the subs will scrape and hopefully not the duals.
I think the pics are with a pro kit.
I've got the same springs with true duals. You'll be fine if you be careful. It's all in how well you get the duals tucked. There's a million and a half ways to mount TSP duals, it takes a while to get it right.
Here are some pics of mine. My car isn't lowered but figured it might help. I can still tuck in the bullets a little better but nothing really drastic.
I have scraped them on speedbumps before
FWIW
FWIW
