Car falls on its face @ Stop signs
Old 01-16-2005, 10:44 AM
Lets Roll's Avatar
Default Car falls on its face @ Stop signs
When slowing down to stop the car will stall if I don't hit the gas. Where should I look to fix this.
Mods:
'02 Z28 M6
TSP 233/239 .603/.600 112 LSA (Just installed)
LT w/ cats to Cut-Out
30# Injecters
Pulley
Lid
I have HPTuners and Idle is pretty good at start-ups. Here is some of what I've done:
Set TB Screw
Idle RPM 875
VE 1200> 60/80/90%
Timming +2 600/800 RPM .08-.32 / +1 1000 RPM /08-.32
IAC Park Position 68*< set to 21.00
Thanks!
Old 01-16-2005, 01:11 PM
99FormulaWs6's Avatar
sent you a PM
Old 01-16-2005, 11:30 PM
Closer_2001's Avatar
Originally Posted by 99FormulaWs6
sent you a PM
Do share!! Same problem here.
Old 01-16-2005, 11:31 PM
Originally Posted by Lets Roll
Set TB Screw
Idle RPM 875
VE 1200> 60/80/90%
Thanks!
Please elaborate on the VE, IAC and timing modifications.
Old 01-16-2005, 11:39 PM
When mine was doing this, I had not adjusted for the injectors. I simply told him what to adjust them to. Another forum member showed this to me, I would have never figured this out, hell I'm still learning to tune. Closer have you swapped injectors?
Old 01-17-2005, 12:00 AM
No, G5X3 in an 04 GTO, stock injectors. No tuning yet, waiting for Hp Tuners to arrive this week.
