Cranks interchangable?
Old 01-16-2005, 02:39 PM
Boomhauer's Avatar
Default Cranks interchangable?
are the LS1 cranks interchangable with the 6.0. more to the point will LS1 cranks work in the 6.0 iron block and up to what stroke
Old 01-16-2005, 02:48 PM
goober35's Avatar
Um that would be the stock stroke. 3.633. Yes it will but it will cost you more in the long run.
The ls1 crank is lighter than the 6.0. This mean at the mechine shop they will have to add more weight. AKA more money.
Old 01-16-2005, 03:31 PM
Boomhauer's Avatar
which companies make stroker cranks for the 6.0 is more what i mean is it the same as the LS1 crank and up to what stroke can you get. all i find LS1 and LS6 specific cranks, no 6.0.
are they the same
Old 01-16-2005, 03:33 PM
SSPerformance's Avatar
are they the same
do a search this has been brought up alot
Old 01-16-2005, 03:44 PM
goober35's Avatar
If it is a Gen III crank it work with all GenIII motor. The 4" crank for the ls1/6 is the same one that will go in a LQ4/9. Call Thunder racing or TSP or any of the other sponcers and they will get u what u need.
