bigger cam than "MS3" without fly cutting
i was wondering if anyone was running a bigger cam than a TSP Magic Stick v.3 ("MS3") Camshaft: 237/242, .603"/.609", 113 LSA with stock heads on a stock bottom end without flycutting the pistons? seems like it is the biggest but i could be wrong.
t-rex doesn't. It's right at about .080 p to v clearance. Im not sure about the juggernaut. And you can run the x3 on 112 w/o you are just pushing the envelope of what's safe.
Nate
Nate
I know the g5x3 will fit on a 114 but not a 112 as told by lou @ LGs the g5x4 will require flycutting. Also depends on gaskets used. Im going to be running a g5x3 cam and AFR 205s and do not have to flycut. Hope that helps a little.
