red calipers?
You don't say what kind of paint you've used in the past but here's a few suggestions, http://www.eastwoodco.com/shopping/...d=caliper+paint or VHT Brake caliper, drum, & rotor coating. You should be able to get the VHT paint from any auto parts store like an AutoZone.
This stuff is a 2 part witha hardner. It's supposed to be like aircraft paint.
http://www.g2usa.com/wheel.shtml
I've heard lots of good things about it.
I've painted calipers twice on my car so far. The first time was the stock LT1 stuff and the second time was the LS1 stuff. Both times i just went and bought a can of brake cleaner and thoroughly cleaned the caliper with an old tooth brush. Then i just painted them Red with Hi-temp engine paint i got at Autozone. I then installed a set of CAMARO caliper decals i bought from Brent on www.cz28.com and the clear coated them several times to hold the decal on. I've had painted calipers now for about 3 yrs and never a problem.
Originally Posted by DCZ_98TA
did this today...........its blue, but you get the point........
first one is down the side after removing the molding and TRANS AM off the side........second one is the reason i had my brakes off in the first place. i will get a better side shot when i get off work............
Originally Posted by planemech2
All I used was Chevy Red engine paint. Been 3 yrs and I haven't had to do anything but wash regularly.
