Anybody ever ran Mallasses in their 10 bolt? :)
Old 01-25-2005, 05:48 PM
LSX Mechanic
Damian's Avatar
Default Anybody ever ran Mallasses in their 10 bolt? :)
Finished putting a 10 bolt together and forgot that the only fluid I had was 85w140. Said fugg it and put it in. That **** is THICK. Anybody ran it with a Torsen diff ?
Old 01-26-2005, 01:20 AM
Croaker's Avatar
LOL...I can't help you out there, I'm just curious why you had such thick oil anyways - what do you use it for?
Old 01-26-2005, 02:33 AM
That's what she said...
TheBlurLS1's Avatar
i ran it for a while in my 10 bolt when i still had the 3.08's hoping they would quiet down some. they diddnt quiet down, and i diddnt notice any difference. i did alot of research and everyone deemed it alright to run that fluid. i wouldnt worry about it! i have an auburn posi, and i added the friction modifier to that weight lube and went to town.
the rear end blew up the other day, but i dont think it was due to the fluid
Old 01-26-2005, 09:54 AM
LOnSLO's Avatar
It'll be fine. I run that stuff in all my rears. It helps to cushion any driveline shock between the R & P.
Old 01-27-2005, 05:08 PM
LSX Mechanic
Damian's Avatar
Eh, I wasnt worried about it. Just curious who's had luck with it. Drove the car today, it's all good
Old 01-27-2005, 05:45 PM
14 Second Truck Club
mzoomora's Avatar
I ran it in a true-trac that I put in for a customer. He used the truck to go hunting, so he put a true-trac in the front to go with the Eaton in the rear. Also towed alot so HE requested the heavier lube. I drove the truck, and it seemed okay, and a torsen and true-trac are very similar. The cold weight is supposd to be the same, dont know if he had any problems though.
