Look what I found on LS2......lol
Old 01-30-2005, 05:34 PM
GueSS Who's Avatar
Default Look what I found on LS2......lol
Originally posted by Sam88Gta1
Coated bearings are a crutch for a poorly built motor.
What do you guys think of this statement???
Old 01-30-2005, 05:52 PM
zamboxl's Avatar
all i want to know is "what is he smoking and where do i get some"
Ben R's Avatar
Agree and Disagree.
Coated bearings are a good insurance policy, much like synthetic oil. Sometimes when you're using weaker blocks and cranks/rods coated bearings might be a good insurance policy to have.
Old 01-30-2005, 05:54 PM
cyphur's Avatar
yea, but KBC....why would you build a motor w/a weaker block and crank/rods? even budget stuff can withstand some serious hp.
Old 01-30-2005, 05:57 PM
zamboxl's Avatar
for that just keep your stock stuff, unless it blew up, but saving a couple hundred aint worth buying crap.
Old 01-30-2005, 06:05 PM
Ben R's Avatar
It'll withstand the power, but that doesn't mean the stuff isn't moving around quite a bit. All it takes is one small mistake and Whammo!
If you've ever taken a 4-Bolt Main SBC block and line-honed it, check it, un-torqued the caps, torqued them back on, and then checked them again, you'll see that you're getting different results. Do this with a DART or Bowtie block and the results will almost be exactly the same.
Imagine what happens to a stock 502 block when you're using an Eagle rotating assembly kit, steel splayed mains, and you're making close to 1500HP. Things move.
Old 01-30-2005, 06:36 PM
GueSS Who's Avatar
I have torqued an LS1 main down and checked it 3 times in a row just to make sure and it was always the same. These motors are really tough. I think that if you are going to put a motor together why wouldn't you put coated mains and rods in. Just the same as if you could coat the pistons.
Old 01-30-2005, 06:52 PM
Ben R's Avatar
Personally I have no problem with coated bearings. We've used them in everything from 100,000 mile stock re-builds to 2000HP BBC/Blower motors. Like I said, they're a cheap insurance policy should something bad happen.
Old 01-30-2005, 08:37 PM
hugger1975's Avatar
if it was from BnG it doesnt count.
forgive them all.
Old 01-30-2005, 09:27 PM
Louis's Avatar
Be nice to sam. heh. Where does he work now?
