Going bigger in the future, plan ahead now?
I've got a 02 WS6 right now (see sig below) and in the next month or so I'm planning on having a custom ground Futral cam put in as well as a 100 shot (dry). Im upgrading to a Walbro255, & I was thinking about some SVO 30#........ but at the same time, the next upgrade will be a forged motor (most likely 370 or 406). Should I go with a bigger injector now? Perhaps a Racetronix 37#? What's the best injector for the $$$? Are injectors easy to tune via HPTuners?
If you're like everyone else here, you'll end up wanting more than you "plan" on right now. You might want to consider a wet kit. With the wet kit, the 30's should be fine even if you decide to up the jets to 150hp or so. Tuning for injectors is very easy with hptuners.
