Balancing a crank?
So there is almost no way you can put your own engine together unless you have the machine to balance this stuff? Do you have to have it all balanced together or can you do seperate pieces? Like if all you already got the crank balanced and just need the rest done?
11 & 7 Second Clubs
Don't try it. Hire an engine builder.
Originally Posted by HAMRHEAD
What is involved in balancing a Crank? I tried searching but it is to general. How do you do it?
Im sure its always the safest bet to hire someone who has done this hundreds of times before. But still, what harm would it be to fill us in on the black art of engine balancing. What tools are used? Where is material taken off? Is that material grinded off or drilled out?Ive heard that a normal balance job costc $150 - $200. On one hand, why not pay someone since its so cheap. On the other hand, how much work could it possibly be if shops only charge $150.
Originally Posted by Grimes
You have to bring your rotating assembly...pistons/rods/crank; sometimes dampner and flywheel to an engine shop to get it all balanced properly.
