TR224 vs. TSP225 Making the final decision
Old 02-15-2005, 10:22 AM
UnleashedBeast's Avatar
Question TR224 vs. TSP225 Making the final decision
I was thinking that both of these cams would produce near the same performance. I have narrowed my cam choice to these two cams, but was trying to make final decision. Both cams will be on a 112 LSA. Dyno sheets would help too if anyone has them.
TR224 - Thought about buying from Thunder b/c I like there service and they treat me right, but for 429.99. I would only spend the added investment if there were added benefits to gain with it.
TSP225 - I like the 389.00 price b/c of the savings over the TR224. If it is going to be the same performance as the TR224 I will chose this cam due to the lower price.
Now, my car is a daily driver not racer. I like the smaller cams for the added torque under the curve. I have/will have all bolts on before the cam install EXCEPT that I will keep the heads (casting 853) stock until I upgrade to 5.3L ported and polished heads. My car will be NA it entire life, no nitrous or forced induction. Looking for that near 400HP/TQ numbers with stock heads.
A member here has helped me a great deal and pointed me to either cam, so let's see where this thread goes. Lay it all out on the line fellas and help me make up my mind.
Old 02-15-2005, 10:30 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
You really can't go wrong with either camshafts! Here is a quick couple of posts from customers running the 225 camshaft.
https://ls1tech.com/forums/dynamometer-results-comparisons/263234-tsp225-mti-stg2e-dyno-results.html
https://ls1tech.com/forums/dynamometer-results-comparisons/208929-prc-225-cam-prc-stage-2-5-5-3-heads.html
I have a couple cam only graphs also if you'd like to look at them
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 02-15-2005, 10:52 AM
jrp
SN95 Director
jrp's Avatar
as stated before, the cams will be near identical. what its gonna come to is price and service. i've bought from both TR and TSP and both are top notch.
Old 02-15-2005, 11:09 PM
https://ls1tech.com/forums/showthread.php?t=263234
https://ls1tech.com/forums/showthread.php?t=208929
Yes Jason, I would love to see them. You can post them here or PM them to me. Thanks
Old 02-15-2005, 11:46 PM
Droptopws6's Avatar
I can only speak on Thunder Racings service and will say it is excellent. I have a link to my video in my sig. your thinking too hard.
Old 02-15-2005, 11:47 PM
Droptopws6's Avatar
Sorry I guess its not in my sig. here it is.
Short video:http://www.mainstreamtopics.com/memb...paolinows6.mov
Old 02-15-2005, 11:53 PM
2c5s's Avatar
Save your money and buy from TSP. They are almost the same cam and Jason will treat you right. No offense to TR, but $$$ talks...........
Old 02-16-2005, 12:08 AM
Damn, your car sounds good.
Old 02-16-2005, 12:09 AM
luv2spd's Avatar
I have nothing but good things to say about tsp and tr. Service is always top notch. Both will perform similarly so I'd base my decision on price.
Old 02-16-2005, 09:11 AM
Ryan02SS's Avatar
TSP 225. In this day and age you can't argue with price or the fact that both are too damn similar to make a comparison. The extra .581 lift of the TSP225 might make a few more ponies once you get your higher flowing heads.
Old 02-16-2005, 10:07 AM
n2o
n2o's Avatar
Jason and TSP are great. I'm sure Thunder is too. Go for the price, the service is there either way.
Old 02-16-2005, 11:31 AM
DanZ28's Avatar
Is price the only consideration when you buy a cam? In this case, maybe so.
The TR224 is well proven and the TSP 225 cam has done quite well. Coin toss?
Old 02-16-2005, 12:10 PM
slow ride's Avatar
I know these cams are about the same. Have you seen posts from gomer? I think he is making like 425/398 with TSP 225 and 5.3 heads. Great combo
Old 03-16-2005, 10:06 PM
Would the TSP225 114lsa cam dyno the same as the 112lsa version? Minor change?
Old 03-16-2005, 11:08 PM
Blacker's Avatar
Go with the FMS F4 (226/226) and they are on sale for $340. It will make about 10rwhp more than the TR224 and will idle better.
Old 03-16-2005, 11:20 PM
My question was about the TSP225, not the TR224. I was recommended the F4 by Kip @ Futral. Don't know exactly what I want to do yet.
Old 03-16-2005, 11:46 PM
35th SS's Avatar
just do the coin toss.both sponsors are excellent.sorry I have no dynos on my tr224 only track time.
Old 03-17-2005, 12:47 AM
Blacker's Avatar
The TR224 is in the title. Maybe I misread something
Old 03-17-2005, 06:03 AM
Last Yellow Bird's Avatar
Default Another option
Not to through a kink in your decision, but you can get a custom grind CompCam 224/224 .581/.581 112LSA from Speed Inc. who are also great to work with for 379.99. So, you get the price that you want, the tested 224 Cam, and the extra lift of the .581 as with the TSP225. Sounds like all the things you are looking for in a CAM all in one place.
